Old 26-10-2005, 07:13 AM   #1 (permalink)
Default Cannot run commands from START-RUN eg regedit, ping, cmd,etc
Hello all the gurus out there
probably related to the 16 subsystem topic but still starting a new thread on this
when i try to use run commands from START-RUN eg regedit, ping, cmd,etc i get the message
c:\windows\system32\regedi.com
config.nt. The system file is not suitable for running MS-DOS and microsoft windows application. Choose "Close" to terminate the application
What is likely to be the problem
Kindly provide a solution
can anybody suggest any other way to edit registry
thanks in advance
aag
aag692k is offline
Old 26-10-2005, 12:54 PM   #2 (permalink)
siriusb's Avatar
I guess you have an XP based system. Here's a microsoft suport article:
http://support.microsoft.com/kb/324767/
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 27-10-2005, 12:17 AM   #3 (permalink)
copy the files- autoexec.nt, cmd.com and config.nt from any other system in which xp is installed from the directory windows/system32
and paste these file on ur system's system32 folder and replace the existing files this should help u
thadhanihemant is offline
Old 27-10-2005, 12:24 AM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
First .. Regedit isnt in System32 folder .. Its in Windows directory .. Secondly its not a Com file .. its .exe .. I am sure you got some kind of parasite on your system .. Continue on your first thread ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
