hey.....trainsim's not working on my system......it used to work on my old p-3 with 160 mb of ram n a geforce mx440...now this is an athlon64 with 512ddr ram and fx5200..... i was jus goin thro' old cd's n came across this...wonder if ne1 knows ne compatibility issues?
The torquemaster rules.
which os u r using becoz train simulator has problems runnig in windows xp
it runs fine in 98 may be u can try using the compatibility mode in win xp if u r using xp otherwise i can't help
