copy-paste the foll maxthons folders elsewhere temporarily. config, groups, plugins, skins, etc.
then install maxthon in ur existing folder. cut paste the removed folders back here again. and check if things work out. this way u will have saved ur existing settings. then update back to 1.5.
if it doznt work, i think u shud do a clean new install.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
