Old 25-10-2005, 05:44 PM   #1 (permalink)
Default Make a folder in "start>programs" menu & move programs to it
Is it possible in win2k and xp to move a group of programs to a folder to make it easier to view in the “start>programs� menu as in Windows 98. In win 98 I know that we can customize the start menu in such way. For instance, wecan move programs like ACD,Irfan view under a new folder called Picture viewer or whatever we name it. But in w2k and xp, I don’t know whether we can do it at all. Please help!
Aanand is offline
Old 25-10-2005, 06:24 PM   #2 (permalink)
yes, ucan do it
the path wud be <windows installed drive>:\documents and settings\<username>\start menu\programs
u can create directoiries here and add as many links as u need... its no different from windows 98, except that there is an user a/c created here.
/legolas
legolas is offline
Old 25-10-2005, 07:02 PM   #3 (permalink)
Thanks Legolas.
I made the directory. But the problem is not all the programs that I can see, when I click on the start button, are there in the start menu folder. How to make them visible?
Win7 Ultimate 32/Intel CLASSIC DG43NB/Intel Core 2 Quad 8400 @ 2.66 GHz/4 GB RAM(2x2GB)/Nvidia Geforce 9400/Seagate 2TB & Seagate 500GB/LG16X/i-ball sprinter500/Samsung740N & SA300/APC ES650VA
Aanand is offline
Old 25-10-2005, 07:55 PM   #4 (permalink)
Originally Posted by Aanand
Thanks Legolas.
Don't forget to look inside "All Users" folder -
drive>:\documents and settings\All Users\start menu\programs
Keith
Keith Sebastian is offline
Old 25-10-2005, 08:38 PM   #5 (permalink)
Yes Keith
Its working. Thanks a lot...
Aanand is offline
Old 26-10-2005, 12:25 AM   #6 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. Easy method is Right Click on Start Button and select Open All users .. There you are .. Move the folder in the Programs folder and then substitute yourusername in place of All Users in address bar .. I do it like that always
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
