Old 24-10-2005, 12:03 PM   #1 (permalink)
Chillum Baba
a_medico's Avatar
Default <HELP> Please suggest a Virtual CD Drive
i need to install a virtual cd drive. There are these couple of softwares i use which pi** me off by asking for CDs every time i want to use them. Just copying the CD contents on HD doesnt work...
So i am looking for somethng like this :-
With Virtual CD you can create compressed 1:1 copies (virtual CDs/DVDs) to your hard drive. You can then store your originals safely in a cabinet! Your virtual CDs are then available with a simple click or even automatically with the autostart of the corresponding program. Nobody needs to handle fragile CDs any more in order to run applications. Music, games, searching programs, grafic programs – all will be loaded faster and is immediately accessible. You can simultaneously use a number of different CD programs without needing to purchase a number of CDdrives this pays off quickly.
VIRTUAL CD seems very big. almost 33mb ...
Can you suggest me some alternatives? Sharewares wouldnt be a problem.
thanks
a_medico
a_medico is offline
Old 24-10-2005, 12:33 PM   #2 (permalink)
Karthiksn
kato's Avatar
hey if u have nero then go for nero imagedrive and if u want the best in the business go for
alchol 120%
i dont know its link coz i use nero image drive
"Walking the Path of Heaven, The Ruler of All."
kato is offline
Old 24-10-2005, 02:10 PM   #3 (permalink)
www.alcohol-soft.com
Shwetanshu Srivastava
shwetanshu is offline
Old 24-10-2005, 02:15 PM   #4 (permalink)
vignesh's Avatar
For a free one use this
www.daemon-tools.cc
vignesh is offline
Old 24-10-2005, 03:40 PM   #5 (permalink)
choudang's Avatar
these are used by me.
1. NERO Image Drive
2. Alcohol 120%
3. Alocohol 52%
Take a ISO modifier like WinISO or ISOBuster to edit your ISO file.
For every action, there is an equal and opposite criticism.
choudang is offline
Old 24-10-2005, 04:20 PM   #6 (permalink)
Dipen01's Avatar
2. Alcohol 120%
3. Alocohol 52%
Why do u need both... i guess one is suffice.. isnt it..?
I love walking in Rain ,because no-one knows i am Crying :|
Dipen01 is offline
Old 24-10-2005, 04:25 PM   #7 (permalink)
Chillum Baba
a_medico's Avatar
thanks alot guys...there was this thing called Virtual CD which was almost 33MB ...
ultimately sombody from the forum suggested me EXTRA DRIVE PRO..
best part is its less than 700k !! and this was exactly the thing i wanted...
thanks for the replies friends...you guys never disappoint me.
a_medico
ps - i will try alcohol Alcohol 120% soon
ps2 - wanted to use nero 7 .. but its too big.. and i really dont feel like installing it.
a_medico is offline
Old 24-10-2005, 05:05 PM   #8 (permalink)
Karthiksn
kato's Avatar
@medico nero image drive comes even with the nero 6 no need to install nero 7
kato is offline
Old 24-10-2005, 07:41 PM   #9 (permalink)
Chillum Baba
a_medico's Avatar
thanks kato... didnt know that actually...never used that function b4... just now switched to nero image drive...and its even better
thankkkkkksssssssssss
a_medico is offline
Old 25-10-2005, 05:51 PM   #10 (permalink)
I recently started to use Alcohol and it was wonderful and user-friendly. It came with the September issue of the Digit in CD or DVD. Give a try.
Win7 Ultimate 32/Intel CLASSIC DG43NB/Intel Core 2 Quad 8400 @ 2.66 GHz/4 GB RAM(2x2GB)/Nvidia Geforce 9400/Seagate 2TB & Seagate 500GB/LG16X/i-ball sprinter500/Samsung740N & SA300/APC ES650VA
Aanand is offline
Old 25-10-2005, 06:25 PM   #11 (permalink)
a_medico, does nero image drive, that comes along with nero 6 bundle read all iamge files, like .mdk extension, .cue files and all?? for me it dint which made me switch to alcohol 120% and its cool!
/legolas
legolas is offline
Old 26-10-2005, 03:30 AM   #12 (permalink)
Learner
Kniwor's Avatar
If u need too many advanced features...daemon
Otherwise alcohol 120% is the best.... I use this
Kniwor is offline
Old 26-10-2005, 10:39 AM   #13 (permalink)
choudang's Avatar
Alcohol 120% is the best, as it has all the extention like .nrg, .cue, .iso etc. Alcohol 52% is same but they have a huge diff. You can make an image by both 120% and 52%, but you can burn it only by 120%. Alcohol 52% does not have that burn image option. and most inst. thing is that when making an image, i found upto 53x [while i have a 52x].
Nero don't have other ext. it is only for .nrg files.
choudang is offline
