Old 04-10-2004, 10:07 PM   #1 (permalink)
mohanty1942's Avatar
Default Mount FAT Partitions in Redhat 9
I can't see my Windows partition in Redhat Linux 9. When I run 'mount' command only the CD-ROM gets mounted.
Pls guide how to view FAT/windows partitions.
mohanty1942 is offline
Old 05-10-2004, 12:14 AM   #2 (permalink)
the mount command by itself will list the currently mounted filesystems and the mountpoints (directories). To mount a Fat32 partition, you can give the following command:
First create an empty directory which will act as the mount point for your Fat partition:
mkidr /winc
now give the mount command like so:
mount -t vfat /dev/hdaX /winc
make sure you replace the X in /dev/hdaX with the partition number of your Fat32 partition. This will mount the fat32 partition on /winc.
To make the partition to mount automatically on each session of Linux, make an entry in the /etc/fstab file.
For e.g for the above partition you can add something like:
#<device> <mountpoint>  <filesystemtype> <options> <dump> <fsckorder>
/dev/hda1         /winc           vfat        defaults      0     0    0
Hope that helps. for more on fstab do a info fstab or man fstab
sailendra is offline
Old 05-10-2004, 12:17 AM   #3 (permalink)
#/bin/sh's Avatar
yes i agree with sailendra.
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 14-02-2005, 05:14 PM   #4 (permalink)
vignesh's Avatar
mkidr /winc
I tried this but it doesn`t work.I want to mount my d partition that is hda5.
tell me what to do.
vignesh is offline
Old 14-02-2005, 09:29 PM   #5 (permalink)
tuxfan's Avatar
Why not take a search at the forum. You should find it easily.
I searched for "mount windows partition" and got 16 unique results here (17th was this thread)!! If at least 1 applies to you, your problem will be solved instantly!!
Take a search mate There may be more threads if you search with right keywords.
tuxfan is offline
