Old 23-10-2005, 06:59 PM   #1 (permalink)
Default VGA Problem
Got an INTEL 810 mother board with no VGA installed.Its showing "Intel 810 graohics controller hub" with an exclamation mark on it in add remove hardware.If i uninstall it the VGA gets installed automatically with the same messege n exclamation mark.But no VGA actually gets installed.Plz suggest something.Urgent.
ra_sriniketan is offline
Old 23-10-2005, 07:29 PM   #2 (permalink)
Try getting updated drivers from the motherboard manufacturers site.
Keith
Keith Sebastian is offline
Old 23-10-2005, 07:50 PM   #3 (permalink)
But there should be a way out to install the driver.But the problem is it automatically installing "intel810 graphics controller hub" and it can't be uninstalled.
Old 23-10-2005, 08:18 PM   #4 (permalink)
choudang's Avatar
can i have some more info about the motherboard. is it INTEL 810 chipset or VIA chipset, name of the manufacture comapny [mercury, priya, vinitron whatever it is]. try to install the VGA with the setup.exe that you have in the board driver CD. if no then try to update driver from the device manager. inform the proper name like Intel 810E, 810et whatever it is
choudang is offline
