Old 23-10-2005, 03:24 PM   #1 (permalink)
Default what it mean?(instrusion attempts)
what it mean?(instrusion attempts)what the hell is doing in my pc?
rajas700 is offline
Old 23-10-2005, 03:59 PM   #2 (permalink)
alib_i's Avatar
Man ! rajas .. you post a screenshot of desktop for everything.
Just in case you didnt know .. ALT+PrintScreen takes the screenshot of only the current window.
Now,
I think the Firewall is treating connection attempts from BSNL as threats. The IP shown there belongs to BSNL's range. I dont think there's anything alarming. But keep your firewall ON.
alibi
-Metallica
alib_i is offline
Old 23-10-2005, 04:56 PM   #3 (permalink)
But the ip changes from time to time...And it is not my ip....
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 23-10-2005, 08:19 PM   #4 (permalink)
crazybutt's Avatar
Dood hav u tried zone alarm firewall
i used to get similar messages with Avast and my airtel connecn.....
after zonealarm nuttin seems to be d prob!!!
crazybutt is offline
Old 23-10-2005, 08:48 PM   #5 (permalink)
No i dont use zone alaram..
rajas700 is offline
Old 24-10-2005, 12:16 AM   #6 (permalink)
its not a PROBLEM !!!
the fact that is that the firewall is WORKING and thats y it shows that msg
otherwise it could mean catastrophe for u
basically its blockin hacker intrusions ..
blockin ppl from gettin into ur system
so thats a good thing !!!! theres no solution to this !!!
the ip shown is the ip of the "hacker"
No Mercy, No Limits.
theraven is offline
Old 24-10-2005, 07:12 AM   #7 (permalink)
How to find it is the IP of hacker can u help me????
rajas700 is offline
Old 24-10-2005, 10:49 AM   #8 (permalink)
Check the logs or something similar for that piece of software.Forgive me but i'm not acquainted with Norton & its products.
The source IP should be the Ip of the remote computer & the destination IP will be your NAT'ed private IP or dynamic public IP.
www.Oobertech.net
digen is offline
Old 24-10-2005, 12:04 PM   #9 (permalink)
puja399's Avatar
Like I told u b4, Zonealarm is THE BEST whether u like it or not!!! So, I am telling u 4 da last time, trash that NIS, nd go 4 ZA. Cheers....
puja399 is offline
Old 24-10-2005, 01:46 PM   #10 (permalink)
no actually zone alarm SUX
yeah u heard me right .. it hurt me as much as it does anyone else ... even more
try the firewall tests
zap failed 2 from the first 3 ..and thats when i just quit even testing it !!
zone alarm apparently has a very bad outbound protection !!! acc. to the tests that is
very very disappointing results
theraven is offline
Old 24-10-2005, 01:56 PM   #11 (permalink)
Theraven can u say how do u find that the IP of the hacker's???
rajas700 is offline
Old 24-10-2005, 02:02 PM   #12 (permalink)
__Virus__'s Avatar
@rajas ^^^^^^^^^^
__Virus__ is offline
Old 24-10-2005, 04:22 PM   #13 (permalink)
alib_i's Avatar
woooof .... what am I seeing here !!
raven saying ZA sux !! .. now that's interesting .. 0_o
and rajas ...
It used to happen to my friend all the time ..
We're inside a LAN and share files using P2P softwares (back then it was Shareaza)
and everytime somebody else's shareaza tried to connect to his computer (while his shareaza was OFF) he used to get an "intrusion attempt".
The firewall treated an outside IP trying to connect to port 6999 (or whatever) as an intrusion attempt.
So, if anybody tries to connect to you through a closed port .. you'll get such a warning.
What I am trying to say is that, these warning you see may not be actual intrusion attempts.
And even if they are ... just chill out ...
as raven said ... your firewall is UP and working .. relax.
alibi
alib_i is offline
Old 24-10-2005, 04:24 PM   #14 (permalink)
jeez how many times do u need to be told !!!
the ip that is shown .. is the ip of the hacker
its right there in front of u
u only said the ip keeps changing
that is the ip of the intruder !!!!
ur ip is gonna reamain constant unless u have dial up
and plz dont use bold the next time .. we can all read
theraven is offline
Old 24-10-2005, 04:59 PM   #15 (permalink)
When i use both windows and norton firewall i dont get such intruder.only i get when i use norton firewall....
rajas700 is offline
Old 24-10-2005, 10:21 PM   #16 (permalink)
eh ? u dun get on norton firewall but u get it when u use norton firewall ??
anyways i dont know what u mean dude
the point is that the fact its reporting it is a good thing cuz its actually blocking it
theraven is offline
Old 25-10-2005, 04:35 PM   #17 (permalink)
Well,could you please tell us what tests u used?
U see I used a s/w called LeakTest and also an online test(sorry forgot the actual URL) and found that the first ~1040 ports are safe (Absolutely safe was how the test put it)
Maybe it was the firewall inside the Huawei modem of mine
And if ZA Pro is bad,could u suggest another Firewall?
BlackIce perhaps?
\"Cogito,Ergo Sum\"
whim_gen is offline
Old 25-10-2005, 07:25 PM   #18 (permalink)
http://www.firewallleaktester.com/ go there and take the tests
i took the first 3 and passed only the first one
so i just quit
till i get a better one
jetico seems nice , batty has been testing it ..
but i just cant get myself to leave ZAP yet
modems dont have firewalls btw
DO post ur results with the firewall leak tests ..
maybe i'll sticky a topic in software section for ppl to post their results ...
look out for it ...
let this thread continue .. we'll have the firewall discussion in another thread .
theraven is offline
Old 25-10-2005, 08:20 PM   #19 (permalink)
^^Strange man.
All the tests but one when run managed to trigger alerts from ZA Pro (version 6.0.667.000) which indicate that indeed my system is safe
And well,the other test (where packets are sent from my PC) that managed to bypass the firewall,is because I have set the TCP/UDP ports as open to enable Shareaza.
Maybe u shud try with the latest version of ZA Pro or someone prolly shud try these tests with ZA Personal edition and post the results here.
\"Cogito,Ergo Sum\"
whim_gen is offline
Old 25-10-2005, 10:52 PM   #20 (permalink)
plz post in the firewall leak test thread i sticked in REVIEW section
@rajas .. if i get it righ u mean when u use both together no alert
when only norton then u do right ?
thats cuz windows firewall is inbuilt into the os
it blocks it before norton can ... hence norton does not detect the intrusion cuz as far as it is conecerned there is no intrusion
i hope thats clear now
theraven is offline
