Old 22-10-2005, 11:09 PM   #1 (permalink)
Default Urgent Help Requested! How 2 delete 'deleted' files?
Hi Digit-ers...
You Gurus gotta help me out. My cousin accidently deleted a folder from my hard disk... I managed to recover 98% of the data with Get Data Back v2.31... But I was horrified to see the partition full of 'deleted' files... Files of stuff of sensitive nature (not porn, don't get any ideas... he he) all over the partition... After recovering the data I had accidently lost, I tried to delete all those old 'non-existent' files, but to no avail... Recommend a good software to trace them all and permanently clear all that junk... It's eatin' up a good 7 GB of disk space!
I tried a software Sure Delete to get rid of the junk... but it did nothing...
Recommend a good software to cleanse my pc... I know that simply formatting the partition won't delete those files...
DigiMorgue is offline
Old 23-10-2005, 12:07 AM   #2 (permalink)
its not eating up any space
its just files that CAN be recovered if u want using these software
as long as u dun run they are pretty much free space
since their entry is removed from the partition table , the space the once occupied is free to be overwritten but other files
No Mercy, No Limits.
theraven is offline
Old 23-10-2005, 09:14 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
several such software like tune-up, system mechanic, ace utilities, etc.
visit www.download.com and look around.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-10-2005, 04:14 PM   #4 (permalink)
those files are not consuming any space on ur HDD ... bcz to ur operating system currently those locations are FREE .. so it'll always treat that space as free space & will overwrite write the information so dunt be much bothered about those files ... recover whichever U want to & leave the rest as they are ...
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 23-10-2005, 04:36 PM   #5 (permalink)
busyanuj's Avatar
what you need is file shredder software which will write 0s in the place of existing files thus deleting the old data.
busyanuj is offline
Old 23-10-2005, 07:14 PM   #6 (permalink)
cybermanas
Posts: n/a
You can try file shredders such as Tune Up Utilities File Shredder or System Mechanic Incinerate to permanently get rid of these files so that these cannot be recovered.
Old 23-10-2005, 07:24 PM   #7 (permalink)
vignesh's Avatar
Try harddisk cleaner.
vignesh is offline
Old 23-10-2005, 09:01 PM   #8 (permalink)
choudang's Avatar
Use File Shredder. Some software like TUNEUP, System Mech. included it.
choudang is offline
Old 24-10-2005, 09:48 AM   #9 (permalink)
EinSTeiN's Avatar
try system mechanic, u can try it for free. Otherwise jus leave the problem.
;) ~~EiNsTeIn~~ ;)
http://www.tejuspratap.co.cc
EinSTeiN is offline
Old 25-10-2005, 11:41 AM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
use cleanup wizard
... W H O T ...
ax3 is offline
