Old 21-10-2005, 08:29 PM   #1 (permalink)
mario_pant's Avatar
Default Edit: DVD not detecting!! HELP!!!
hey mann...
i bought a Sims 2 compendium DVD.....
i brought it home put it in the Combo drive....
and then.....
nothing happened....
the drive is not recognizing the DVD....
is there some way to get it done or do i have to get the DVD exchanged..... the problem is that no one near my house has a DVD drive so i cannot test it there too....
this is so pi$$ing me offff.....
please can someone help me and QUICK!!!!
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 21-10-2005, 08:58 PM   #2 (permalink)
thrash_metal's Avatar
check the drive for dust and lense probs !! Also check ur drive by inserting another DVD into the drive and c wether its detecting it . If everything with the drive is fine the check wether your drive supports double layered disc (if tht Dics u bought is double layered) .. If none of these work then take it to the person from whom you bought it from and get it checked there !
Ps : As i was told .. please be specific in the titles of your post . Give a lil title considering your problem rather then desperate help needed .
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 21-10-2005, 09:09 PM   #3 (permalink)
mario_pant's Avatar
can u be more specific as to how shud i check for lens dust....
i tries a GTA:SA DVD it worked.... digit DVDs are not also detected.....
I just upgraded my firmware... no use....
I use a samsung combo....
Old 21-10-2005, 09:13 PM   #4 (permalink)
use a lense cleaner ......
I had a similar problem with My old Lg DVD Rom ..... it used to detect DvD's sometimes only .. but luckily i thrashed it and got a Sony DVDRw .. no such problem since !
PS : Does you DVD Drive also break CD's ?? cause mine used to and a lot of !
Old 21-10-2005, 10:25 PM   #5 (permalink)
mario_pant's Avatar
uber cool mann....
just flicked in my audio lens cleaner and now everything works fine.... thanks dude!! *y didnt it trigger in my mind??*
Old 21-10-2005, 10:28 PM   #6 (permalink)
Laptoping
Sourabh's Avatar
Prob solved! No use of keeping the thread running.
Locked
Sourabh is offline
