Old 04-10-2004, 03:20 PM   #1 (permalink)
Default R-CONNECT PROBLEM
Recently I bought a LG-RD2030 handset alongwith Reliance R-Connect Data cable (LG make). When I try to install the Dialer from CD, getting a message " Sorry, cannot detect the phone as modem on port:COM1" . I tried the connect the second serial port. no use. I'd disabled the second port and tried the each availble IRQ settings on COM1. still not working. The datacable and handset setting is all OK. Even if I manually install LG serial modem and try to dial the #777 number, the ERROR-692 pops up but handshaking with modem is working. I use WINXP professional and the M/Board is ASUS A7N-V22. Please help me.
venu2004 is offline
Old 04-10-2004, 06:46 PM   #2 (permalink)
Ya man !! I have a LG landline , it has the same problem
Me - Gone :(
sr_ultimate is offline
Old 04-10-2004, 06:55 PM   #3 (permalink)
set the sio baud-rate of your phone(in the additional menu) to 115,200 and try again. if it does'nt work get a serial to usb convertor and retry by connecting the phone to your usb port, after setting the baud rate to 115,200. if it still does'nt work, contact the reliance helpdesk.
hope it helps...
technomodel is offline
Old 04-10-2004, 07:44 PM   #4 (permalink)
NikhilVerma's Avatar
Well I had the problem too....
But I solved it!!
You have to forcibly install the driver of your LG phone first...
Then run the setup to install the dialer...
NikhilVerma is offline
Old 05-10-2004, 12:57 PM   #5 (permalink)
nipun_the_gr8
Posts: n/a
i didn't face any probs while installinin'
Old 05-10-2004, 06:32 PM   #6 (permalink)
I'd tried all the said steps. nothing works. the reliance help desk made statment that my 'COM port or M/board have problems'. converting serial to USB is not workin' in this case.
venu2004 is offline
