| Forum |
| View Poll Results: Which are better | |||
| Branded |
2 | 7.14% |
| Assembled |
26 | 92.86% |
| Voters: 28. You may not vote on this poll | |||
#1 (permalink) |
vsWizard |
#2 (permalink) |
Definitely assembled !! One of my friends got a assembled PC! With assembled Pcs u can customize a lot !!! and plus u save a lot of money.
My frnd got the following config for 28k : P4 2.8 prescott, 256(400mhz), intel 865 based mobo, SATA HDD 80gb, 17' inch monitor.
www.techenclave.com Ecumenical Technology ! |
#3 (permalink) |
branded 4 me. i used a compaq 4 5 years and now i hav been using a dell 4 2 years. but it is upto personal choice. i am against assembled comps coz i hav seen friends get bad ones. neway, i believe d best option is 2 assemble 1 urself. that way, u r totally satisfied with what u get and only u r 2 blame if nething goes wrong!
#6 (permalink) |
My vote is definitely for assembled PC's. You can assemble a PC by your needs according to the budget. Adn believe me nothing is more cost effective as this.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15"..... |
#7 (permalink) | |
@ TechEnclave
"Do u think Branded PCs are worth their price?" I say No
Madman @ TE |
#9 (permalink) |
Assembled i say ...
The main problem with branded is that they are not well balanced. Especially so for lower priced pcs, they give you 2.5 ghz + P4 processors which you dont need, and just 128 MB RAM. Installing more yourself may void your warranty, which defeats the purpose of a branded PC
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e |
#11 (permalink) |
Hay,
no one can deny that a branded pc is very good. But the main problem with branded PC's is that their configuration is fixed. if we want to change one config. they apply prises according to as their own brand which is Rs. 200/- to Rs. 300/- more than it's market price. if you are going for assemble a pc by any hardware shop then problem comes of their commision. & surely they are taking their commisions throug different H/W devices. so according to me you should go for assemble your pc your own with the help of a hardware friend. Go with him at laminthon & buy the devices at their own prices. if you have no hardware friend then also so many H/Wman are present their. i think they will take appro. Rs. 200/- to Rs. 350/- to assemble your pc. & it is very comfortable. just you verify that the h/w device you are going to buy is working well or not. so Go for assembling a PC. Bye.... "Any suggestion about anything will always accepted." |
#13 (permalink) | |
#14 (permalink) |
Posts: n/a
Both considiring there market & department
Home users find assembled better cos they have a lot of choices to select from, Intel or AMD, nvidia or ATI, etc, branded, there is usually limited choices The worst thing with branded, fast & top of the line CPU, but 128MB RAM, 7 low end gfx card, i mean today I was looking in a paper & there was an ad of PCS computers, they were giving Athlon64 PC in Rs 25k, specs are Athlon64 3000+ with 128 MB RAM & GeForce 5200 card with 128 MB RAM, now U with only a few choices to be made when it comes to selecting other parts The biggest reason for costly branded PCs is Licensed Softwares, which are original be it WIndwos XP or NAV or Nero, which we save money by going for assembled, since software means a CD only which can be copied we can pirate it However, for offices assembled are a compleate no no. reason, with assembled they need to use their own assets & pay for it for the support required, like minor software quirks etc, with branded they get the service free, also when they make their yearly tax return & accounts they cannot show that they used pirated softwares as it is illegal & they can be called in the court, so they have to use original softwares, which U either need to buy seperatoly or buy with the PC in form of branded PC |
#16 (permalink) |
Well IF one has even slighest of Knowledge about Computers he/she should go for the Assembled (Make sure u oversee what they are putting yourself). The branded ones are for newbies..
With assembled one could get dumped with inferior quality product, which is not a case with branded ones with their high Quality Controls. Guarantee could be a problem with assemblers. You would have to keep track of each part on your own. With branded like HP, IBM this wont be a problem as its a one stop solution Upgrading becomes a huge problem with branded. When i had tried to upgrade my RAM from 64 MB to 256 the Compaq guy gave me a Quote of 8000 bucks two years ago where as the mkt price was around 3000.And if u add product not from your company ur guarantee stands VOID. The reason i am still stuck with 64 MB RAM LASTLY there is always a price difference of about 15Ks between branded and assembled. Bcos branded guys give u ORIGNAL WINDOWS XP, where as the assemblers give u the pirated copies (but who cares) Finally my vote for ASSEMBLED machines.
Have a Nice Day Mohammed Muchhala, © 2006, All Rights Reserved http://www.muchhalasworld.com |
#17 (permalink) |
Assembled,assembled,assembled...
I would like to think about the assembled ones as your own child & branded ones as adopted ones....if u spend a couple of days doing your homework,u can come up with a value for money config tailor made for your needs.... I hate compaq as i know atleast 3 of my friends having very bad experiences with them....thank god atleast now they have stopped giving 128 RAM with XP......... |
#18 (permalink) |
no choice here b'coz it all depends upon ur choice of components.branded pcs od ALIENWARE are unmatchable and certainly DELL"s workstation vry good performance but they are way too costly. as is said all depends upon your choice of components. today u can get a branded (withiut windows) with Athlon64 3000+ and SATA, AGP 8x along with onboard video in about Rs.21000 8) . cool right.
but assembled ones hav their benefits like the ability to b customized. hey buddy if u hav money go 4 "power pc G5". but assembled vs branded is sumthing like "Rupa" vs "Jockey"
Q : What\'s Flash ? A : The fastest thing in the world. Q : Who am I ? A : The Quickest [flAsh] |
#20 (permalink) |
Assembled all the way for me...!!!
though i learned frm the mistake i made around 5yrs ago going for HP branded stuff....but ya at that time i was a newbie to PC stuff...so kind of mixed feeling for me in that purchase!!! |
#21 (permalink) |
Šupər♂ - 超人
Assembled was my option 3 yrs ago... mine is assembled.. by the way
But now.. i would go 4 a COMPANY-ASSEMBLED COMPUTER.. , i mean... some companies give assembled computers as per our config. with an xtra 1000/-... not big comparing what i get (i get services as well as my required pc config.) Goin 4 a high-performance machine nxt... bahut din hua games khelkar.. my computer doesn't play the latest... DX9 games.. 32bit vaale...
Windows ka tashan... koolbluez ishtyle - http://lin.cr/ss I almost forgot this - http://www.thinkdigit.com/forum/showthread.php?t=6242 |
| Bookmarks |
| Display Modes | |
