Old 21-10-2005, 07:51 AM   #1 (permalink)
Default why i get like these??
why i get like these?when i run some games in windows xp???
rajas700 is offline
Old 21-10-2005, 09:51 AM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Did u screw up any files of NFS while installin the game?? Please take a back up of ur saved games folder and then reinstall the game again..also check for any conflicts of DIRECT-X i guess i faced the same problems and a couple more wen i also usd to play NFS2 SE, i faced video problems.. so i jus simply uninstalled the game..
Neways jus try reinstalling the game and post ur results...
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 21-10-2005, 10:12 AM   #3 (permalink)
It works fine in widows 98.And no need of installation.And i face the problem with windows xp only.No problem in direct x 9.0c.and videos.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 21-10-2005, 10:37 AM   #4 (permalink)
cybermanas
Posts: n/a
Have you copied the files from a CD or installed it using it's executable.
Old 21-10-2005, 11:05 AM   #5 (permalink)
Asterisk enthusiast
abhasbajpai's Avatar
this is not the problem with win xp or installation
actully need for speed sereise before hot pursuite II or NFS 7 was nt made to run on nt core. lk NFSPU or NFS V porcshe unleshed cannot run on win NT or 2K or XP unless you patch it or rename a dll file.
so your NFS II cannot run on xp unless you patch it
try to google it for the patch then only you can run it on xp
abhasbajpai is offline
Old 21-10-2005, 12:55 PM   #6 (permalink)
will u help me to how to google with it???
rajas700 is offline
Old 21-10-2005, 03:08 PM   #7 (permalink)
Run this in compatibility mode. It should run.
Delpiero is offline
Old 21-10-2005, 03:27 PM   #8 (permalink)
will u explain in full manner???
rajas700 is offline
Old 21-10-2005, 03:45 PM   #9 (permalink)
Right click on the exe file and select properties. Go to Compatibility Tab and place a check on "Run this program in compatibility mode". Try setting to Win98 compatibility and if it doesnt work, Win95 compatibility..
Arun
sakumar79 is offline
Old 21-10-2005, 06:31 PM   #10 (permalink)
Right click on the NFS2.exe file, check compability box, choose windows 98,click OK. Now run the game.
Delpiero is offline
Old 22-10-2005, 05:55 AM   #11 (permalink)
BUT FAILS TO WORKS IN THAT compability MODE...
rajas700 is offline
Old 22-10-2005, 11:08 AM   #12 (permalink)
Asterisk enthusiast
IT will NOT RUN in competability mode
i am trying 2 find a solution for you
since NFS II is pretty old it will take time
i am also NFS Series FAN espesialy NFSPU
by default PU also nt run on NT CORE lk NT,2K, XP
if u run it will dump the core on disc
mean while
can you send me the list of DLL files you hv in installation folder
as i dont hv the copy of this game
Old 22-10-2005, 12:46 PM   #13 (permalink)
This are the DLL file i have it u need that dll file ???
rajas700 is offline
Old 22-10-2005, 07:05 PM   #14 (permalink)
Wire muncher!
infra_red_dude's Avatar
nfspu and nfs2se work absolutely fine for me in xp in compatibility mode. no patching needed for me!! even for many of my frenz. i guess the problem is something else.
its not related for directx either,for sure. its the file incompatibility wid nt core.
dunno how it works for me!!! hey make sure none of the files haf the read-only tag.
infra_red_dude is offline
Old 22-10-2005, 07:45 PM   #15 (permalink)
alib_i's Avatar
Well, it runs perfectly on my Windows XP without any Compatibility Mode setting !!
I think, if it's not a valid Win32 application .. then it's not a valid Win32 application. It's not the correct file. Most probably, the file is corrupted.
You know what, do one thing ..
# Download a small ( 80kb ) free utility called FSUM
# Place the exe file in your C:\Windows\System32 folder ( dont worry it's not a virus or spyware etc )
# Now go to Start -> Run -> type "cmd"
In command prompt window .. type
F:<enter>
cd "NEED 2"<enter>
fsum nfs2sen.exe >new.txt<enter>
There will be a file by the name new.txt in your "F:\NEED 2" folder. Post the contents of that folder.
I get the following md5 sum ..
30e8950b5f36d22a27c25bf080dea541 *NFS2SEN.EXE
What is expected is that you and others should get the same MD5 sum.
Others also post their MD5 sum .. may be, my file is corrupted.
alibi
alib_i is offline
Old 23-10-2005, 06:30 AM   #16 (permalink)
well as doing ur procedure i dont get new.txt in"F:\NEED 2" folder.for MDS sum see my screenshort.
rajas700 is offline
Old 23-10-2005, 02:59 PM   #17 (permalink)
alib_i's Avatar
ohh .. the whole idea of new.txt was that you dont post another screenshot.
You forgot to write ">new.txt" in fsum command ... read my last post carefully.
Anyways .. we have the checksum visible in the cmd prompt window and it's surely different from mine.
I seriously think your nfs2sen.exe file is corrupted.
Just wait for some more time and see if somebody else comes up with any other possible reason.
alibi
-Metallica
alib_i is offline
Old 25-10-2005, 10:04 AM   #18 (permalink)
Distinguished Member
anandk's Avatar
i had a similar problem, with a difrnt game. see if this thread helps u.
http://www.thinkdigit.com/forum/view...ht=recoil+demo
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
