Old 20-10-2005, 11:13 PM   #1 (permalink)
Default i am being prompted to go to Add or Remove Programs
Whenever i try to install any new software i am being prompted to go to Add or Remove Programs for this reason - "A terminal server must be in installation mode before you install a program. When you use "Add or Remove Program" in the control panel to install a program, this automatically puts the terminal server in the install mode." What can be done to this?
prashanthmpai is offline
Old 20-10-2005, 11:36 PM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
please tell ur environment details.
i mean ur Operarting System,ur antivirus ,or u may post a log of Hijackthis , so that geeks here(not me) can analyse n solve ur problem better.
n00b forever...
~Phenom~ is offline
Old 20-10-2005, 11:50 PM   #3 (permalink)
Default I am using Windows 2000 Server OS
I am using Windows 2000 Server, Norton Personal Firewall and Protector Plus 2000 antivirus.
Old 21-10-2005, 03:40 AM   #4 (permalink)
__Virus__'s Avatar
are you on network and is terminal server (for remote desktop) installed onto your system and is someone connected to your system through remote session?
__Virus__ is offline
Old 21-10-2005, 01:38 PM   #5 (permalink)
Default I am using a bradband connection Sify
I am using Sify broadband for internet and i recently formatted my C drive and then installed Windows 2000 Server. Before i had 2000 Proffessional OS. Thsi problem started after instaling Server OS
Old 21-10-2005, 09:47 PM   #6 (permalink)
i guess the terminal services are on by default in the SERVER version of win2000
i tried googling for common error msgs so i could explain better but i couldnt find it
try shutting down terminal service from services.msc and give it a try
No Mercy, No Limits.
theraven is offline
