Old 18-10-2005, 11:24 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Memory bolcked as per Task Manager???
Hello friends!
Please check the snap of the task manager that I have included along with. Can anyone please tell me the details of the processess that are using my computers memory as well as my processor speed. Please also tell me which are the different process that I can switch of without any problems. I am really concerned about the top 5-6 processes as they are blocking most of the memory.
Thank you.
go4saket is offline
Old 18-10-2005, 11:40 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Clean .. Though you can get rid of Machine Debug Manager .. I dont trust Webshots too ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 19-10-2005, 12:05 AM   #3 (permalink)
alib_i's Avatar
aah .. system idle process is eating all the CPU ..
jokes apart ...
everything looks fine to me too except that Machine Debugger Manager (MDM.exe)
Firstly .. it's quite useless .. Read this for "How to Turn Off the Machine Debug Manager"
Secondly, it could be a trojan too. Read THIS
Just check on that.
alibi
-Metallica
alib_i is offline
Old 19-10-2005, 12:36 AM   #4 (permalink)
Netjunkie's Avatar
You can disable SPOOLSV.EXE if you are not using a printer. Its turned ON by default even if you dont have a printer connected to your system.
Netjunkie is offline
Old 19-10-2005, 12:59 AM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can safely disable following services:
hkcmd.exe (used to enable hot keys for changing screen resolutions)
igfxtray.exe (used to show system tray icon for screen resolutions)
MDM.exe (as it_waaznt_me suggested)
spoolsv.exe (as Netjunkie suggested)
Webshots.scr (as it_waaznt_me suggested)
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 19-10-2005, 09:00 AM   #6 (permalink)
Distinguished Member
anandk's Avatar
check these two threads too :
http://www.thinkdigit.com/forum/view...light=services
they will help u !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 19-10-2005, 10:09 AM   #7 (permalink)
9437077259
go4saket's Avatar
What is the functiuon of SVCHOST.exe
This seem to block most of the memory. Is it safe to turn off this feature...
go4saket is offline
Old 19-10-2005, 11:31 AM   #8 (permalink)
__Virus__'s Avatar
http://www.google.co.in/search?hl=en...HOST.exe&meta=
__Virus__ is offline
Old 19-10-2005, 07:50 PM   #9 (permalink)
Or more helpfull A description of SVCHost.exe in Windows XP ...
Old 19-10-2005, 07:51 PM   #10 (permalink)
champ_rock
champ_rock's Avatar
no spyware there.... chillax
Registered Linux user number 400618
champ_rock is offline
Old 24-10-2005, 11:34 AM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
i have these msmsgs.exe, alg.exe processes ...
for wot is this exe file ???
if possible, how 2 diaable it ???
... W H O T ...
ax3 is offline
Old 24-10-2005, 01:51 PM   #12 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Hey guys even im posting the link to my TASK MANAGER screenshot,Please advise me wat services to disable so tat my PC is atleast a bit faster..Can i disable the SYSTEM IDLE process as (according to me) it eats up a lot of CPU process
Also tell me wat STARTUP items i can disable from the msconfig screen...(screenshot of top part of startup screen)
(bottom part of startup screen)--->
Cheers n e-peace.......
ashu888ashu888 is offline
Old 24-10-2005, 03:23 PM   #13 (permalink)
9437077259
go4saket's Avatar
sorry ashu888ashu888, but there's no screen shot... Plz check it out...
go4saket is offline
Old 24-10-2005, 04:40 PM   #14 (permalink)
alib_i's Avatar
@ashu
# Cant see the whole list in task manager. You should have resized the task manager.
# From what I can see, do you frequently use InCD ? if not, then switch it off.
# You probably resized the 2nd and 3rd pic ... I cant understand anything there.
# IMP: Next time you take a screenshot of taskmanager/msconfig .. single click anywhere on the window .. and press ALT+PrintScreen (insteasd of only PrintScreen).
It will take a screenshot of only the active window. Just like go4saket's pic.
alibi
-Metallica
alib_i is offline
Old 26-10-2005, 01:20 PM   #15 (permalink)
Hey thanx a lot alib_i for helping in how to take a screen shot of a particular screen actually i was using Ctrl+Print scree to take a screen shot and didnt knw how to take a screen shot of a particular window..thanx alot again bro
Neways I am again posting a screenshot of my TASK MANAGER so please suggest me wat processes to keep and wat to disable..
Also tell me how can i maximise the startup window in msconfig so tat i can take the screenshot of the entire screen (without the scroll bars included) coz in my previous post aslo..i couldnt get a whole screen for the Start up so had to mention it as TOP and BOTTOM part of the screen.
Cheers n e-peace...
Old 27-10-2005, 04:01 AM   #16 (permalink)
alib_i's Avatar
Nothing much to be done in Task Manager ..
For msconfig ..
It cant be maximized .. but
You can use other softwares ex. Regesupreme Pro to get the list.
In regesupreme, go to 'starting programs' tab and click File -> Save list as.
Many other such utilities can help you in this respect.
alibi
-Metallica
alib_i is offline
