Old 17-10-2005, 02:59 PM   #1 (permalink)
shakti's Avatar
Default HIBERNATE
I AM NOT ABLE TO ENABLE HIBERNATE IN MY PC.
RUNNING WIN XP SP2
When set the chekbox it's display one error.
"IT IS ALRESDY USED BY ANOTHER PROCESS".
PLZ HELP
Mr. Infredible
shakti is offline
Old 17-10-2005, 04:11 PM   #2 (permalink)
Well,
Have u enabled hibernate mode?
If not,go to Control Panel>Power Options.
There u will see a tab called Hibernate.
Just check the
 Enable Hibernate Support
option.
\"Cogito,Ergo Sum\"
whim_gen is offline
Old 17-10-2005, 07:05 PM   #3 (permalink)
godsownman's Avatar
Your system might not be supporting Hibernation.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 18-10-2005, 08:18 PM   #4 (permalink)
cybermanas
Posts: n/a
Go to Control Panel ---> Power Options ---> Hibernation.Enable hibernation there.
Old 18-10-2005, 11:52 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
Can u support ur comment?? i would like to know that if i have windowsXP SP2 with enough disk space then in what Circumstances my system is not gona support Hiberneting....????
@shakti.. do this,
& check this out...
How to Choose Hibernate on the Shutdown Dialog
then post back...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-10-2005, 12:18 PM   #6 (permalink)
shakti's Avatar
Dear Friends It's Giving Me Error
" It is already used by another process"
so plz help.
Mr. Infredible
shakti is offline
Old 19-10-2005, 01:38 PM   #7 (permalink)
Have a look to see if your hard drive already contains a Hibernation File -
c:\hiberfil.sys (Presuming your WindowsXP is on C:\) Note that the file
is both Hidden and a System file. Running the command dir c: /as from a
command prompt will show it.
If it's there despite Hibernation currently being disabled, delete it and
then try enabling Hibernation. If you can't delete it, check you have Full
Control security permissions on the file. If still you can't remove it, try
booting to the recovery console and removing it from there.
If the file does not exist, check you have enough free space on that
partition for the file - you will need as much free space as you have RAM.
Arun
sakumar79 is offline
