Old 17-10-2005, 02:45 PM   #1 (permalink)
Default How to change the joyies website???
Hi guys,
I was not able to change the the website address www.joyiex.com. i have tried running spybot, anti-hijacker and anti-adware, run the norton AV. But still not able to change the website address its greyed out. i also tried to delete from registry but still no go . Pls give some suggestion which is practical .
regards
Ranjit
raj16 is offline
Old 17-10-2005, 05:15 PM   #2 (permalink)
According to http://www.avira.com/en/threats/TR_Lewor_F_details.html this virus is the same as http://securityresponse.symantec.com...startpage.html which should be detected by AV with updated definitions. If NAV did not detect it, try to run NAV scan in safe mode. Also available in NAV site is manual removal procedure...
Arun
sakumar79 is offline
Old 18-10-2005, 02:46 PM   #3 (permalink)
Default Joyiex.com
hi,
what i noticed is its downloading some spywares and toolbars like stars or something related to that any way thanks for the suggestion
yar
ranjit
raj16 is offline
Old 19-10-2005, 12:10 AM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Please post your HijackThis Logfile for better assesment of your problem.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 19-10-2005, 02:16 AM   #5 (permalink)
mario_pant's Avatar
yah... i learned that lesson a LONG time ago... u should ALWAYS post the HijackThis log when there is a prob....
HijackThis ROx!
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 19-10-2005, 05:05 AM   #6 (permalink)
Fresh Stock Since 2005
I think Ad-Aware SE from lavasoftusa.com should solve your problem..............
http://www.khattam.info
khattam_ is offline
Old 19-10-2005, 06:57 PM   #7 (permalink)
Default hi
its nothing to do with adware it wont work i have already tried it
raj16 is offline
Old 28-10-2005, 08:50 PM   #8 (permalink)
I think Ad-Aware SE from lavasoftusa.com has solved my such problem in the past, if I reember.............
khattam_ is offline
