Old 17-10-2005, 01:18 PM   #1 (permalink)
Default CD Drive icon disappears!!!
Hi all,
My friend is having one peculiar problem . His CD drive icon gets disappears
some times.
I checked with my CD drive and also with others but same problem encounters.
He has Dual OSes but the same problem found in both OSes.
Some Times it detect and some times it doesn't.
So i guess CD Drive might not be in problem .
Is it a problem due to BIOS or Motherboard or something else ?
so please tell me what might be the problem and how to solve it .
Thanks
m.parthiban is offline
Old 17-10-2005, 01:31 PM   #2 (permalink)
champ_rock
champ_rock's Avatar
yeah i think there is some prob with the data cable... or the motherboard... get ur motherboard checked with a pro
Registered Linux user number 400618
champ_rock is offline
Old 17-10-2005, 04:39 PM   #3 (permalink)
damnthenet's Avatar
There may be a prob in the cable!
Sony Xperia Neo V - Review and Discussion Thread:
http://www.thinkdigit.com/forum/mobi...ml#post1520514
damnthenet is offline
Old 17-10-2005, 05:19 PM   #4 (permalink)
Learner
Kniwor's Avatar
I'd never get a pro check my pc, i doesn't feel nice to me, pay someone else, any they dont know anything often...
check another cable or port...
Kniwor is offline
Old 19-10-2005, 03:06 PM   #5 (permalink)
bizzare_blue's Avatar
some times.
There may be a few reasons for such happenings:
1. Loose connections at CD-ROM drive's or MB's end(Data cable or Power cable)
2. Faulty Data Cable.
3. Faulty IDE slot.
4. Faulty CD-ROM drive.
5. Faulty Motherboard.
Check for the above stated in problems in the order given.
Firstly tighten the data cord and the power cord at both the ends. If this does not solves the prob then try to use another data cable. Thirdly, connect the the data cable to the second IDE slot. Next, plug-in somebody else' CD-ROM and see if its functioning; if it is then ur CD drive is faulty. If this too doesn't help, then try out the last step of plugging ur drive into ur friend's PC and checkin whether its running...if it is, then probably there's a prob with ur MB as u have already checked ur IDE ports earlier(in step3).
PLEASE REMEMBER:To Check whether the drive functioning correctly at every step.
Hope this will solve ur prob. You'll need a gud frend who will trust u in doin all this.
P.S. All this was in referrence to your friend i.e. taking YOU as the victim of a Faulty CD-ROM drive so act accordingly. And do let me know if it still has a prob after doin all this.
Bitten by the open-source bug...
bizzare_blue is offline
Old 19-10-2005, 03:21 PM   #6 (permalink)
some times.
3. Faulty IDE slot.
Old 19-10-2005, 07:25 PM   #7 (permalink)
champ_rock
champ_rock's Avatar
as u wish.. but dont mess up...
