Old 17-10-2005, 12:38 AM   #1 (permalink)
yjs
Default Unable to use Rewritable DVDs.
I have Samsung CD&DVD Writer model is "TS-H552U". it works fine with all types of CD both CDR and Rewitable CDs. Also it works fine with write once DVDs.
Recently I purchased "Meser Bear" 2.4X DVD+Rewritable media. It is not writing on this media saying that media is not compatible. I have tried Nero 6.6.0.15 and also Win XP's inbuilt DVD writer option.
I feel that it is the 2.4X fixed speed for DVD writing of this media which is not supported by Nero 6.6.0.15, as i am usalyy writing at 2X, 4X or 8X.
Can someone suggest a solution or any other DVD buring software which supports 2.4X DVD buring speed.
An early reply will be very much helpful to me.
yjs is offline
Old 17-10-2005, 01:19 AM   #2 (permalink)
2.4X is definitely supported by Nero. You're problem is either a faulty disc or incompatiblity (with you're burner).
Keith
Keith Sebastian is offline
Old 17-10-2005, 01:24 AM   #3 (permalink)
Learner
Kniwor's Avatar
As keith said, is unlikely that it's nero, but sometimes some writers dont like some discs, i have faced this problem in past, neither the disc is faulty nor the writer, so i'd suggest u try the disc on another writer first, if it orks, try disc on ur writer from some other manufacturer
Kniwor is offline
