Old 16-10-2005, 04:18 PM   #1 (permalink)
harish_21_10's Avatar
Default SATA ll
I have few questions regarding SATA ll ,so thought why not post it here.
1. How much is the performance difference between a SATA and SATA ll
2. Can SATA ll hard disk be use on a motherboard that doesnt support it but supports just SATA
3. Which motherboards with 939 socket support SATA ll
4. Advice me a SATA ll hard disk and is it worth it?
NOBODY is PERFECT and i am NOBODY
harish_21_10 is offline
Old 16-10-2005, 05:26 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
1. The perfomance difference theoretically is supposed to be double .. but practically i dont know if its dat much but there will surely be some diff between the perfomance.
2. SATA II is backward compatible with SATA so it will work on a SATA supporting mobo at SATA speeds.
3. All Nforce 4 chipsets support SATA 2 .. good ones are ASUS A8N-E , ASUS A8N-SLI PREMIUM , MSI K8NEO4 PLATINUM etc.
4. I suggest going for a SATA II HDD from Hitachi as their prices are almost the same as SATA and they come with a 5 year warranty .. there is no sense in buying SATA now when SATA II is available and that too at the same price.
mohit is offline
Old 16-10-2005, 06:02 PM   #3 (permalink)
Mohit thanks for ur reply,now got the info. i needed about SATA 2.If come up with any new query with it,will post them here
Thanks again
