Originally Posted by cryptid
@Mohit
Wat about the Intel 945G chipset it suppose to have onboard 256mb vga is that good enought for gaming (the latest high graphic games) or after buying this chipset can i add another Graphic card to it like a 128mb graphic card will it increase my gaming experience(will the 256 onboard and 128 graphic card acts together and become 384mb graphic card)
Who on earth told you this chipset or say this motherboard has 256MB onboard VGA ?
Actually, the capacity of the onboard VGA depends on your installed RAM.
The onboard VGA uses a shared memory with your installed RAM.
Hence when you have say a 256MB DDR RAM installed, the onboard graphics chipset will configure itself to use a minimum of 8MB and maximum of 64 MB by default for use as a Graphics output capacity from your 256MB RAM.
So, the system will get 256 - 64 = 201 MB of available memory with it.
However, you can install more RAM and increase the capacity of the Graphics to 128 or 256MB , if you install a totol of atleast 1 GB or more RAM.
And hence, no one does it practically. And people opt out to buy a Graphics card instead.
