Old 15-10-2005, 06:41 PM   #1 (permalink)
Default How to Update Bios
I have Bought AMD Sempron 2500+(64bit)..But in Windows It shows AMD processor Model Unknown....
I know tht Updating My bios Will remove this Discrepancy....But I have heard tht Updating Bios can also render yr MObo useless if something goes wrong....So can Anybody tell How to Do it,And any Safety Precautions...
My mobo is Gigabyte having a Q-flash Utility....
Has Anybody Tried this utility....
See Ya!
dabster is offline
Old 15-10-2005, 07:08 PM   #2 (permalink)
Learner
Kniwor's Avatar
There is no standard procedure to upgrade a BIOS, it varies from manufacturer to manufacturer...
just download the latese BIOS and there will be instructions on how to do it, u can always use a floppy to upgraade anyhow,
I myself use Winflash to upgrade, this upgrades from inside windows, give it a try if it detects ur mobo, then use it.
Kniwor is offline
Old 16-10-2005, 08:53 AM   #3 (permalink)
Manchester United
abhijit_reddevil's Avatar
Hello,
I searched the net and found the following useful articles for you:
http://www.ehow.com/how_8227_upgrade...ters-bios.html
http://www.pcguide.com/ref/mbsys/bios/compFlash-c.html
This is more in general.
And this is for specific Gigabyte motherboards.
http://www.gigabyte.com.tw/MotherBoa...oReflash_1.htm
Hope this helps.
But please do keep in mind that wrongly updating BIOS can damage your board permanently.
abhijit_reddevil is offline
Old 16-10-2005, 11:09 AM   #4 (permalink)
mario_pant's Avatar
is double posting allowed?
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 16-10-2005, 03:52 PM   #5 (permalink)
Learner
Kniwor's Avatar
What is that question????
Kniwor is offline
Old 16-10-2005, 04:17 PM   #6 (permalink)
vignesh's Avatar
Its a risky job dude.Be sure of what your doing ....
vignesh is offline
Old 16-10-2005, 06:44 PM   #7 (permalink)
mario_pant's Avatar
mann...... i just reported that thing and it was a sarcastic comment!!!!
our friend digitized had doubleposted.......
Old 17-10-2005, 03:06 PM   #8 (permalink)
shakti's Avatar
PLZ, Do It carefully ,
because it's too risky.
follow the suggetions made.
all the best.
Mr. Infredible
shakti is offline
Old 17-10-2005, 04:54 PM   #9 (permalink)
Manchester United
And let us know of the results.
Old 17-10-2005, 05:17 PM   #10 (permalink)
I am too scared of doing it,that's Why i asked for Views...
Here too, many people say to be very careful...
Anyways current Bios version doesn't bug me except that Windows properties shows tht Processor Model is not known....
Any Other Advantage of Doing It ???
dabster is offline
Old 17-10-2005, 05:33 PM   #11 (permalink)
Learner
Kniwor's Avatar
You might have additional functionality, i flash my BIOS everytime a new one's out, be sure to hae a UPS, it only takes seconds, nothings scary, so dont worry and go ahead, winflash is damn easy, but make sure it has identified ur mobo...
And dont do without battery backup like ups, incase the power goes off...
Kniwor is offline
Old 18-10-2005, 10:58 AM   #12 (permalink)
if u are not facing stability/performance issues with the mobo flashing it is not recommended.
however if u read and follow teh instructions which come with ur new bios, i m sure u wud be able to get it right
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 18-10-2005, 07:12 PM   #13 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
My suggestion, make sure your UPS is working alright and gives at least 5 mins of backup! When your UPS is fully charged, disconnect the power supply, and flash the bios on UPS battery only, so that nothing can go wrong!
kalpik is offline
Old 19-10-2005, 06:29 PM   #14 (permalink)
EinSTeiN's Avatar
ok, flasing bios is a risky thing. But its quite easy the only point u have to take care of is that u have an uninturrupted power supply. And check if if ur bois supports flashing. Then u can use a bios update.bin file and a bios flashing tool such as winflash or any other boot time flashing software.
Just be careful of the power supply. gud luck.
;) ~~EiNsTeIn~~ ;)
http://www.tejuspratap.co.cc
EinSTeiN is offline
