I have WIDCOMM bletooth adapter. But the problem is when I resume my system from stand-by, I get an error saying USB deviced not recognised. Same thing happens if I restart my PC.
I have installed all the drivers properly.
I have XP running on AMD 64
__________________ There is a very fine line between genius and insanity. I have erased this line.
It happens to me most of the times as well - i also get a bluetooth device not found error -- i just plug it out and back in -- starts working !!! Maybe you could try that .
if it does not work you could try removing and reinstalling the drivers on your system .
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
change the power management. goto usb controllers and uncheck the opton "allow to turn off this device". do the same for the bluetooth adaptor and see if it helps.
