Hey thanx alot guys..
Incredible, rohanbee, Generic and alib_i thanx for ur responses. Well yes i will make sure tat during startup i reduce the amount of resources from un necessary starting up and making my system slow down. Also i will install MS OFFICE 2000 on D:drive
I hv an updated version of Lavasoft's Adware 1.06 and Spybot S&D 1.4 and i frequently check my system for Spywares
and update the definitions as well.
The Incredible wrote:
ashu888ashu888 wrote:
i hv NAV 2005 and NIS 2004 installed (on C:drive) and the system is starting and shutting down preety fast and normally.
YOU MUST B JOKIN'!!!!
SYSTEM WORKIN' FAST WITH NORTON INSTALLED.
Man, first of all, i'll say better use any other AV such as McAfee...
Well Buddy i am not using any other paid Antivirus as my NAV 2005 is a pirated version and it has a crak wich wen installed,makes my NAV 2005 valid for 1 year..
(but tat is a different story..
And yes even i was surprised myself that my system was running preety fast even thou i installed NAV and other Norton related products..
Neways thanx for all ur replies guys..!!
And yes i will install all my games onto my E: drive..
I hv also noticed tat wen ever i run "msconfig" and remove unwanted programs from startup like MSN and Y! msngr, and choose
SELECTIVE STARTUP ,I always keep geting the
SYSTEM CONFIGURATION UTILITY wenever my system starts
dnt knw how to fix this up.. plz help
Also since i hv not installed MS OFFICE onto my system,there is a folder in START>ALL PROGRAMS menu having a folder named as
STARTUP so if i install MS OFFICE onto my system,the STARTUP folder will obviously show the MS OFFICE in it,so shud i delete the MS OFFICE from the STARTUP folder by right clicking it or shud i disable MS OFFICE from the
msconfig command ??
Cheers n e-peace...
