Old 15-10-2005, 10:16 AM   #1 (permalink)
sujithtom's Avatar
Default Voice Converter. Is there any??
I want a software which will convert a natural recorded voice to a robotic voice (like the compter song of Venga Boyz). Is there any such software? If so can u tell me from where to download it.
P.S No spamming plz. Don't say to google it because i have already done it.
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 15-10-2005, 10:33 AM   #2 (permalink)
EinSTeiN's Avatar
I dont know if there is a software which directly converts song to robotic voice but i hav done in another way. Download jetaudio and play the song with the robotic effect. Now record it in realtime by using another instance of jetaudio or total recorder and save the song. I think tht it will work.
EinSTeiN is offline
Old 15-10-2005, 12:32 PM   #3 (permalink)
sujithtom's Avatar
will give it a try thnks
Old 15-10-2005, 11:29 PM   #4 (permalink)
The Incredible's Avatar
do u know which version supports it. do all versions hav robotic effects.
can i play an .mp3 file n use da same mentioned for natural recorded voice???
The Incredible is offline
Old 17-10-2005, 12:02 PM   #5 (permalink)
EinSTeiN's Avatar
The robotic effect is there in the v.5.0 and v 6.0 of jetaudio. And we can mix any music being played in the computer and mix our voice in it using the same software.
;) ~~EiNsTeIn~~ ;)
http://www.tejuspratap.co.cc
EinSTeiN is offline
Old 17-10-2005, 01:39 PM   #6 (permalink)
champ_rock
champ_rock's Avatar
try to use some sound modification software...
or modify ur own voice...
Registered Linux user number 400618
champ_rock is offline
Old 17-10-2005, 06:11 PM   #7 (permalink)
sujithtom's Avatar
Thats the point of opening this thread
LOL
Old 17-10-2005, 08:18 PM   #8 (permalink)
suggest me if any software is around for it freely
Old 17-10-2005, 09:54 PM   #9 (permalink)
champ_rock
champ_rock's Avatar
dont know about any soft but i was talking about talking like a robot...
HELLO MASTEr HOW R U without expressions...
Old 18-10-2005, 05:08 PM   #10 (permalink)
sujithtom's Avatar
U r on the wrong track. Completely misleading the threads orginal purpose. No doubt the mods lock threads whose purpose have been met
Old 19-10-2005, 09:01 AM   #11 (permalink)
EinSTeiN's Avatar
hav u tried the jetaudio tatal rocorder combo. it woks dosnt it?tell me ur exp.
;) ~~EiNsTeIn~~ ;)
EinSTeiN is offline
