Old 14-10-2005, 09:35 PM   #1 (permalink)
q3_abhi's Avatar
Default Can Service Pack 2 be a culprit??
I have installed Service Pack 2 on my PC.
Now whenever the Computer starts, n if i navigate to -
Start>Connect to> Dial-up,
the Start Menu hangs. Other activities can be carried out smoothly.
Menu responds after 10 min n so. I have to wait for 10 min to connect to the Internet.
I have Celeron 1.7, 256 RAM. So is it Becoz of Service Pack 2??
Becoz this wasnt the problem before.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 14-10-2005, 10:38 PM   #2 (permalink)
rohanbee's Avatar
could be i think xp on its own takes up a lot of memory and hence that could be , what is causing you a problem.
Quote by Garfield'
rohanbee is offline
Old 14-10-2005, 11:43 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its bcoz it seraches for all the connections in connect to folder.
Simply make a shortcut of ur connection at desktop or quick launch bar and start always from there...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 15-10-2005, 05:21 PM   #4 (permalink)
Generic Superhero's Avatar
Default Patience....
vishal gupta is right. in my pc (256 mb ddr +p4 2.4ghz +intel 865) running win xp sp2 the same prob occurs when try to conect from start menu. using a desktop sh cut solves it.
BUT if i stand by for a 40-50 seconds until all app-s (antivir & firewall which r in startup) have fully initialized, then i can smoothly connect via the start menu. i do this actually and so have dun away with the desktop sh cut.
Nipon
Generic Superhero is offline
Old 16-10-2005, 08:00 AM   #5 (permalink)
q3_abhi's Avatar
I made a shortcut from the Start Menu>Connect to>Dial up to desktop, but it didnt help.
q3_abhi is offline
Old 16-10-2005, 03:03 PM   #6 (permalink)
why not? it shud work...
clik on network connections on ur desktop...then clik 'view network connections' in the task pane at the left of the window. u can see the dial-up connection there. right clik and click 'create shortcut'.
Nipon
Old 16-10-2005, 09:57 PM   #7 (permalink)
q3_abhi's Avatar
Did the same but still takes time.
q3_abhi is offline
