Old 14-10-2005, 11:42 AM   #1 (permalink)
Default BSOD after installing webcam
i installed creative webcam pd1100 from the drivers suppiled to me by creative online. i installed them properly and it asked to connected the cam. wheni did. a new hardware found window cropped up but it didnt find the drivers.
i tried to reinstall but it didnt ask for uninstall. i tried manually all the installed ddl files looking at the files xtracted in the temp folder.
but everytime i shutdown my system i get this BSOD
saying
windows has been shutdown
--DRIVER-IRQ_NOT_LESS_OR_EQUAL
this prob is caused because of some hardware or software u have installed/updated, etc. etc.
TECH. INFO.=
STOP:0x000000D1 (0X00000040, 0X00000002, 0X0000001, 0XF93F6150)
wanarp.sys- address F93F6150 base at F93F1000,
DATE STAMP 41107689---
they have sent me a dsriver cd free of cost. till then can i do anything??
HP DV 9222tx laptop
core2duo 1.66 @533
512 x2 =1gb ram @533
80x2=160gb hdd
17" widescreen.
nvidia geforce 7600go 256mb
vantec lapcool 3
hauppage usb TV stick with remote
GunshotSilence is offline
Old 15-10-2005, 02:50 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Hey buddy did u plug in the CAM into its port while the SYSTEM was switchen ON ??
If yes: Then shutdown the PC and first plug in the CAM into its port then restart the PC and the FOUND NEW HARDWARE WIZARD will be brought up and then u can install the drivers.
If no: Then check for compatibility issues of the WEBCAM with ur system.
Also if the FOUND NEW HARDWARE WIZARD does not install the drivers fro the LOCATION SPECIFIED then u can pop in the CD and go to START>Right click MY COMPUTER>Select PROPERTIES> HARDWARE>DEVICE MANAGER>click the SCAN FOR HARDWARE CHANGES tab>right clik on the webcam icon (if ur system has detected it) > Double click it>choose REINSTALL the DRIVERS.
Hope this solves ur problem...
Please post ur results for us to help u better..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 15-10-2005, 11:06 PM   #3 (permalink)
The Incredible's Avatar
eh.. What is BSOD?
plz answer in ur own language instead of copying and pasting plz...
The Incredible is offline
Old 16-10-2005, 12:10 AM   #4 (permalink)
alib_i's Avatar
BSOD = Blue Screen Of Death ... n00b
There has been some discussion about similar problem earlier.
I dont know if it'll be useful for you or not. Just check out these links
http://www.thinkdigit.com/forum/view...&highlight=irq
alibi
-Metallica
alib_i is offline
Old 16-10-2005, 01:28 AM   #5 (permalink)
i have a usb adsl modem and on another usb port i have an extension cable for pendrive or webcam
HP DV 9222tx laptop
core2duo 1.66 @533
80x2=160gb hdd
17" widescreen.
vantec lapcool 3
Old 16-10-2005, 12:47 PM   #6 (permalink)
alibi
Dont Joke Man, I really don't know plz tel me. I know only one thing dat it is sumhow related to computing but dunno how. i've read it many times but dunno wat it means. plz tel me. plz.
Old 16-10-2005, 02:07 PM   #7 (permalink)
Yes Incredible, alib_i is rite, BSOD is known as the BLUE SCREEN OF DEATH. Everyone has got this Unlucky screen at sumpoint on thier PC as this really makes ur heartbeat go NUMB....
In general simple terms: This screen is basically a WINDOWS screen wich is brought up if any hardware/software things go wrong in ur system and this screen wen displayed also tells u this This screen has been shown to prevent ur system from further damage.
Since we all users ues this LINGO (language) so it is known as the BSOD: BLUE SCREEN OF DEATH.
BTW,Hey GunshotSilence buddy ! Did ur problem get solved as the description given by me.. ?? I hope u r plugging the WEBCAM into its port wen the PC is switched OFF.....and plz try changing the ports and do post ur results.
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
