Old 11-10-2005, 07:56 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default Is SDRam 64mb,66mhz available.
I'd like to know whehter SDRam 64mb,66mhz for Pentium 133mhz computers are still available? How much wud they cost?
Charley is offline
Old 12-10-2005, 12:45 PM   #2 (permalink)
They would be on SIMM slots then...Im guessing.
I have some SDRAMs with me in working condition but no machine. I shall have a look at it & get back.
I have a Kingston 128MB SDRAM @133MHz.
Will that do fine?
theexister is offline
Old 12-10-2005, 01:00 PM   #3 (permalink)
Just Do It
Charley's Avatar
Nope, 133mhz [128mb] will not work.......
The engr insisted on 64mb SDRam, 66mhz only as that only suits Pentium 133mhz computers.
What do u mean by SIMM slots? How do i check it?
Charley is offline
Old 13-10-2005, 01:25 PM   #4 (permalink)
rohanbee's Avatar
asked for something close to that and the price was fairly steep, just a case of demand and supply i guess and this guy was out to make a quick buck, so when i backed out he suddenly dropped prices..
Quote by Garfield'
rohanbee is offline
Old 14-10-2005, 09:59 AM   #5 (permalink)
I think the one I have is a 32MB 66MHz SDRAM.
If its ok then I can will give it for free since they are just lying around.
Old 14-10-2005, 01:00 PM   #6 (permalink)
Just Do It
Charley's Avatar
Do u have 128mb, 66mhz or 100mhz SDRams?
Charley is offline
Old 15-10-2005, 12:02 PM   #7 (permalink)
The kingston I have is 128 MB 100Mhz but I used it for an AMD 266Mhz.
The 32MB I mentioned I was using it on a Pentium 133Mhz.
I shall confirm in a day.
Old 15-10-2005, 03:42 PM   #8 (permalink)
Just Do It
Charley's Avatar
Havent u any 64mb Sdrams for p133mhz?
Last evening an engr checked on the SDRam with 32,64,128,256 mb's and none detected. All of them showed 64mb[EDO, existing memory] when the sys boots..
Why is it and what can be done?
Charley is offline
Old 15-10-2005, 04:15 PM   #9 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
I faced this sort of problem .. sometime back
for the PC100 to be used on my previous AMD-K/6-2 500Mhz
You are facing the similar problem..
I suggest you to go to the your bangalore version of NehruPlace of delhi..
and Check this out at the old stock shop..
I can tell you the place here in delhi .. but i cant tell about your place
rollcage is offline
Old 15-10-2005, 04:35 PM   #10 (permalink)
Just Do It
Charley's Avatar
Well what did u do then, and is it compatible now?
Charley is offline
Old 15-10-2005, 06:42 PM   #11 (permalink)
rollcage's Avatar
Yes I got the 32MB & 64MB PC100 from NP
And Ya the PC is still working fine now...
rollcage is offline
Old 15-10-2005, 08:10 PM   #12 (permalink)
Just Do It
Charley's Avatar
But whats the reason the SDRAM slot doesnt detect the rams[32,64,128,256mb,66mhz or 100 mhz]
Charley is offline
Old 15-10-2005, 08:43 PM   #13 (permalink)
rollcage's Avatar
That can happen in two cases
1. The Ram fsb is not matching with MB
--> Check the manual of your motherboard
2. The motherboard has went worng .. there may be a fault in DIMM slot
rollcage is offline
Old 15-10-2005, 08:46 PM   #14 (permalink)
Just Do It
Charley's Avatar
Oh well. So what has to be done in either of the 2 situations.
Charley is offline
Old 15-10-2005, 09:03 PM   #15 (permalink)
rollcage's Avatar
Are you dumb ..
I have written that
1. READ THE MANUAL OF YOUR MB
2. in second case .. if the MB is faulty .. YOU HAVE TO GET IT CHECKED
but dont ask from where!
rollcage is offline
Old 15-10-2005, 09:12 PM   #16 (permalink)
Just Do It
Charley's Avatar
Are you dumb ..
I have written that
M8, dont piss off ..... The comp was assembled by an engr abroad abt 6-7 years ago and he didnt give me a DAMN manual as u mentioned and I cant ask him either for one now. :roll:
I'd appreciate if u dont ruin this thread any further. I'll wait for the other dude to respond.
Charley is offline
Old 15-10-2005, 09:22 PM   #17 (permalink)
rollcage's Avatar
M8, dont **** off ..... The comp was assembled by an engr abroad abt 6-7 years ago and he didnt give me a DAMN manual as u mentioned and I cant ask him either for one now. :roll:
ok.. ok..
Then cant you say that ... you asked what i already posted!
What is your motherboard ??
rollcage is offline
Old 16-10-2005, 02:27 PM   #18 (permalink)
Just Do It
Charley's Avatar
All I know is its Intel.
Charley is offline
Old 19-10-2005, 12:47 PM   #19 (permalink)
Apologies for the late reply. I was taking sometime to check the RAM modules.
I dont have a 64MB module. As I mentioned earlier, I have a 32MB module & a 128 MB module.
Old 20-10-2005, 04:19 PM   #20 (permalink)
Just Do It
Charley's Avatar
And u will it give it for free[both of them]?
Charley is offline
Old 20-10-2005, 09:36 PM   #21 (permalink)
Yes...I can give them both for free since I have no use for them.
Old 21-10-2005, 05:13 AM   #22 (permalink)
Just Do It
Charley's Avatar
Pls chck PM
Charley is offline
Old 24-10-2005, 04:57 PM   #23 (permalink)
Just Do It
Charley's Avatar
M8,
R u there? Pls lemme know.
<< Cheers >>
Charley is offline
Old 03-11-2005, 10:00 PM   #24 (permalink)
Hi...sorry for no replies.
I was busy with work and then Diwali time I was out of town.
I took snaps of the RAM modules to explain the SIMM & DIMM cos they fit in differently. I just wanted you to know.
One RAM Module is 32MB SDRAM 66MHz DIMM
The other older one is only 16MB DRAM SIMM
Old 06-11-2005, 01:17 PM   #25 (permalink)
Just Do It
Charley's Avatar
m8, can u send the SDRam only.
Charley is offline
