Old 11-10-2005, 02:26 PM   #1 (permalink)
Default OS selection blues
hii
i had win 98 installed on my P4 Pc. later i installed win xp. it was showing win xp as the default.
but then i needed to reinstall win 98 due to some software problems
and now its showing win 98 as my default and i have to select win xp each time from my selection list
can any one tell me how to make my default as win xp again
mayur_2009 is offline
Old 11-10-2005, 03:23 PM   #2 (permalink)
Netjunkie's Avatar
When you boot into Win XP, right click on "My Computer" & select "properties".
Then onto the "Advanced" Tab, & click on the "settings" button under "Startup & Recovery".
There you can see a pull down menu which shows your default OS.
Set it to Windows XP & click OK.
Netjunkie is offline
Old 11-10-2005, 03:46 PM   #3 (permalink)
alib_i's Avatar
Go to command prompt ( in XP, I'm not sure if it works the same in 98 )
Type "bootcfg"
It will list the entries in boot.ini file with their ID no.
Now if WinXP shows up in ID 1
type "bootcfg /default /ID1" in commd prompt
or if WinXP has ID 2
then type "bootcfg /default /ID2"
alibi
-Metallica
alib_i is offline
