Old 11-10-2005, 01:05 AM   #1 (permalink)
Thor's Avatar
Default IE7 Beta Not Installing :(
Installation Halts..giving the following error
Hv WinXp, SP2 .Intel Celeron 1 GHz, 256 MB SD RAM, 80 + 40 GB HDDs , Ran the Setup From HDD.
Thnks.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 11-10-2005, 01:09 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
mebbe memory to run it too low i guess, wird really....
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-10-2005, 07:57 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
what is the source of the installer file?? try obtaining it from other source, then try the installletion...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-10-2005, 11:12 AM   #4 (permalink)
Thor's Avatar
Source : DIGIT DVD Sept. 05
I am already satisfied with Opera and Starting to like Avant Browser...So I don't think I am gonna trouble myself with the burden of Dwnlding 10.0MB Setup file from any other Source thru my BLOODY Dial -up...
Thnks anyway.
Any more ideas..?
Thor is offline
Old 11-10-2005, 11:15 AM   #5 (permalink)
Commander in Chief
installation hangs at wat time ?
after valdiation or before ?
if u really wanna use it u can extract and create a file called iexplore.exe.local ND RUN IT THAt way...
Harsh J
www.harshj.com
Old 11-10-2005, 11:36 AM   #6 (permalink)
hey please any one tell me form where i can download IE 7 Beta!
Is it only for MSDN subscribers?
sudeepg123 is offline
Old 11-10-2005, 11:51 AM   #7 (permalink)
Thor's Avatar
Installation Hangs After Validation..DUring BAcking up Old Drivers..
Its only For Registerd Beta Testers..and MSDN Subscribers of MSDN. Though u can get it from DIGIT/CHIP/PCQUEST DVDs/CDs..
Thor is offline
