Old 10-10-2005, 11:07 PM   #1 (permalink)
Default What does drwtsn32.exe do ?Please help !!!Urgent
Hi
Everytime i open explorer or start windows media player they both stop responding and i have to kill the process.
In the list of processes there is this process drwtsn32.exe which was never seen before.
Is this a virus,
if so i have Norton Antivirus upto date in virus definitions and even after a full system scan,no virus is found.
Then what is it?
Please help me.
I run Win XP with SP2.
Thnx
rachitar is offline
Old 10-10-2005, 11:36 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Dr Watson is Window's debugger .. It generates debug log for admin to analyze what went wrong when a program crashed ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 10-10-2005, 11:56 PM   #3 (permalink)
Can i disable it?
It seems to be causing more trouble than helping me,as it is i am not going to debug.
Thnx
rachitar is offline
Old 11-10-2005, 01:07 AM   #4 (permalink)
Netjunkie's Avatar
Dr Watson is not a system process, its only a background process.
There are instances when Dr Watson crashes itself.
You can safely turn it off. See this for instructions on disabling it.
http://support.microsoft.com/default...b;en-us;188296
Netjunkie is offline
