Old 10-10-2005, 08:59 PM   #1 (permalink)
Default unusual computer behaviour please help
I have a p4 2.60c, 865 gbf,512 ddr 400 ram, 128 mb fx5200 nvidia graphics card, pctv pinnacle tv card, d-link 10/100 lan card, creative 5.1 live sound card, 80gb samsung 7200 rpm hard disk, samsung 52x24x52x cd writer and a liteon 16x dvd rewriter. The samsung hard disk is in the primary master, liteon dvd writer the secondary master and samsung writer as secondary slave. The operating system is Windows XP. All the drivers are up to date.
My problem is that before i bought the liteon dvd writer My computer was working with a samsung dvd rom drive. As I removed the dvd rom drive the computer now boots very slowly. The booting time has increased from 30 seconds to 2 minutes. The cds I write also take a long to write as the recorder buffer does not get full at all. It fluctuates between 10 - 70 %. Due to this the dvds I write at 8x take an hour to burn but are in good shape because of liteon . I have defragged the hard drive, cleaned the pc of all the dust and changed the ide cables but to no avail. I have also run the pc without the dvd writer but it still does not run quite well. Please help me. I cant solve the problem.
A program is a device used to convert data into error messages.
samrat_chak1 is offline
Old 11-10-2005, 02:03 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
about CD writting Speed,
Do u have the DMA enabled?? if not then enable it...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-10-2005, 03:04 PM   #3 (permalink)
MAYBE UR OLD SAMSUNG DRIVERS ARE A PROBLEM
Education... has produced a vast population able to read but unable to distinguish what is worth reading
AGENT_SMITH is offline
Old 12-10-2005, 06:51 PM   #4 (permalink)
Default no drivers installed for samsung
The DMA is enabled and the I did not install any samsung drivers for the cd-writer.
Old 12-10-2005, 07:28 PM   #5 (permalink)
champ_rock
champ_rock's Avatar
try removing the dvd drive... does it work then ....
Registered Linux user number 400618
champ_rock is offline
Old 12-10-2005, 07:32 PM   #6 (permalink)
Removing the DVD writer or the CD writer does not help.
Old 12-10-2005, 08:28 PM   #7 (permalink)
champ_rock
champ_rock's Avatar
i think ........... ........... if the prob arisese due to it... then removing it will solve it
