Old 10-10-2005, 08:42 PM   #1 (permalink)
Default WMP10
now mp10 USED to work properly...
but lately....its not importing all the songs from a folder.
I have a collection of about 2800 songs, but it imports only 380 of them
i had to reimport all the files one day, and suddenly, only 380 songs!!!
please help
Intel PIV 3.4 GHz, D915GAV Mobo, 1GB Ram, Nvidia Geforce FX 6600GT 128MB
direct_2d is offline
Old 10-10-2005, 08:57 PM   #2 (permalink)
champ_rock
champ_rock's Avatar
if u use ms products then the best solution is to reinstall it... i would say reinstall it or ask the ms people about it
Registered Linux user number 400618
champ_rock is offline
Old 10-10-2005, 09:02 PM   #3 (permalink)
The thing is...its not only Media Player
Even JRiver and others (Other than Winamp) have the same problem
Old 11-10-2005, 05:00 AM   #4 (permalink)
Learner
Kniwor's Avatar
and u can play all the songs?
Kniwor is offline
Old 11-10-2005, 01:51 PM   #5 (permalink)
if i go to the folder and open the song, it opens...but MP doesnt import it
Old 12-10-2005, 07:31 PM   #6 (permalink)
cybermanas
Posts: n/a
Reinstall mp10 because winamp is importing the songs.So it must be a prob. with mp10
Old 12-10-2005, 07:32 PM   #7 (permalink)
champ_rock
champ_rock's Avatar
@cybermamanas
he says that winamp has the same prob
Old 14-10-2005, 09:55 PM   #8 (permalink)
no prob with winamp.....but everything else
Old 14-10-2005, 10:27 PM   #9 (permalink)
mario_pant's Avatar
mann... just copy the songs to a new location.... and then try.... select all of em.. and just drag everything on your wm10 window.... tell me if it worked.....
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 15-10-2005, 11:26 AM   #10 (permalink)
cybermanas
Posts: n/a
Originally Posted by champ_rock
@cybermamanas
Read it yoyrself champ_rock
Old 15-10-2005, 05:01 PM   #11 (permalink)
champ_rock
champ_rock's Avatar
ok sorry man... eyes can be mistaken ...
try logging in as administrator of the system and then try....
it can be some privelege thing..... with ur account....
