Hi,
Open a new file in NotePad and copy the contents of the below "Code" box:-
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\InformationBar]
"FirstTime"=dword:00000000
Go to File Menu (in NotePad) >
Save AS and type the filename as
Fix.REG and save the file. Exit from NotePad.
Double-click on this file, and click "Yes" to merge it to Registry.
Restart the PC, and check whether you receive the "Information bar" or not.
