Old 09-10-2005, 11:17 AM   #1 (permalink)
Default suggestion for upgrade needed?
i was looking for upgrade for my comp.
my budget is Rs. 13000 for a cpu, Mobo, and a 80gb SATA HDD
i have 6600 256 mb AGP 8X card so no need for on board graphic card
i aslo have 2x 512 zion pc3200 2-3-3-5 ram so dual channel is a must
i presently own PIV 2.4 with 845chipset mobo
pls suggest an config with prices (Preferably kolkata price)
Happy Computing :lol:
krishnathelord is offline
Old 09-10-2005, 12:19 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
i dont suggest u upgrade your cpu as u have an agp 8x card and all the new procc have mobos designed for them which use pci express and if u try buying a socket 478 3.0 ghz intel it wont be in your budget. instead do this,
keep the same procc
get an asus p4c800 series board (intel 875p chipset) - around 6,000/-
Hitachi 80 GB SATA 2 HDD - around 3500/-
i am suggesting a sata 2 hdd as its backward compatible with sata 1 and atleast it will be future proof.
keep the remaining cash !!
mohit is offline
Old 16-10-2005, 03:56 PM   #3 (permalink)
i ws thinking to buy a pIV 2.66 (lga775) with asrock mobo 775Dual-915GLhttp://www.asrock.com/product/product_775Dual-915GL.htm with 80 gb sata samsung hdd total around 6+4+3=13K
Old 16-10-2005, 04:15 PM   #4 (permalink)
vignesh's Avatar
i think mohit is right.Don`t upgrade unless you really need to.
vignesh is offline
Old 16-10-2005, 04:45 PM   #5 (permalink)
Why upgrade? Still there are who using P3s, Only go for Sata2 HDD. If you are in gaming then go for 160 GB!
vishalbhatia is offline
- by bhaskar
- by soumya
