Old 01-10-2004, 09:36 PM   #1 (permalink)
Default PHP ODBC Connection failed , Sql Server 2000, help
Folks ,
AM trying to make connection with the Northwind database(SQL server 2000 usiung PHP but i get this error . Help me , am begineer
Warning: odbc_connect(): SQL error: [Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user '(null)'. Reason: Not associated with a trusted SQL Server connection., SQL state 28000 in SQLConnect in c:\web\odbc_connection.php on line 2
Connection Failed:
************************************This is my code *********
<html><body><?php
$conn=odbc_connect('northwind','','');
if (!$conn)
exit("Connection Failed: " . $conn);
} $sql="SELECT * FROM customers"; $rs=odbc_exec($conn,$sql); if (!$rs)
{ exit("Error in SQL");
} echo "<table><tr>";echo "<th>Companyname</th>";
echo "<th>Contactname</th></tr>";while (odbc_fetch_row($rs))
{$compname=odbc_result($rs,"CompanyName");$conname =odbc_result($rs,"ContactName");echo "<tr><td>$compname</td>";echo "<td>$conname</td></tr>";}
odbc_close($conn);echo "</table>";?></body></html>
Flip like a butterfly, sting like a bee
Butterfly is offline
Old 02-10-2004, 12:10 AM   #2 (permalink)
did u create a dsn
i thnk thats the problem
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 02-10-2004, 02:04 AM   #3 (permalink)
#/bin/sh's Avatar
needs to contain your user name and password i belive like...
$conn=odbc_connect('northwind','$USERNAME','$PASSW ORD'); (assuming i don't have that backwards)
Good Luck!
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 02-10-2004, 11:22 AM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
Nope... he did'nt create a DSN... i talked to him on messenger... Did you succeed in creating a Data Source ?
http://web.gnuer.org
GNUrag is offline
Old 02-10-2004, 10:19 PM   #5 (permalink)
Version 2.0
Deep's Avatar
yup i too think, that could be the problem...
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 03-10-2004, 09:55 PM   #6 (permalink)
Default Guys < Thanks My ODBC Connection worked
Folks
Yeah my connection part worked , am so happy , catch ya latter
- by bhaskar
- by soumya
