Old 08-10-2005, 03:44 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default Using msn thru Trillian ,not workin
It says connection to msn failed while I connect to msn using Trillian, why? Is there any settting that needs to be tweaked?
Charley is offline
Old 08-10-2005, 05:41 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Make sure u enter your FULL email address when it asks for your MSN id.
kalpik is offline
Old 08-10-2005, 06:54 PM   #3 (permalink)
Just Do It
Charley's Avatar
k,i didnt know that. In yahoo msgr in trillian it connects with the login and pw ..
Lemme try it
Charley is offline
Old 08-10-2005, 07:01 PM   #4 (permalink)
kalpik's Avatar
Yeah yahoo connects only via the ID but for MSN, you have to enter your full email address. Post back if it works!
kalpik is offline
Old 08-10-2005, 07:05 PM   #5 (permalink)
Just Do It
Charley's Avatar
it doesnt work, same error. Wht r the settings for MSN in ur trillian preferences.
Charley is offline
Old 08-10-2005, 07:08 PM   #6 (permalink)
kalpik's Avatar
Hmm.. actually im not using trillian. But have used it though. But im pretty sure that u have to enter your email address for MSN. But obviously that is not the problem in your case! Have u given access to trillian in your firewall?
kalpik is offline
Old 08-10-2005, 07:09 PM   #7 (permalink)
Just Do It
Charley's Avatar
no firewalls in my comp
Charley is offline
Old 08-10-2005, 07:11 PM   #8 (permalink)
kalpik's Avatar
I guess you should wait for someone with trillian installed to answer! But as far as i remember, i didnt have to tweak it at all! It just worked! Sorry!
PS: Check if u have the latest version. Also check you have the latest version of the MSN plugin. Cuz i now remember i had to download the updated MSN plugin manually to make it work!
kalpik is offline
Old 08-10-2005, 07:16 PM   #9 (permalink)
Just Do It
Charley's Avatar
i have trill v0.635n. AIM,Yahoo,etc work, except MSN. I dont think a plugin is necessary, something to do with the options in it.....
Charley is offline
Old 08-10-2005, 07:18 PM   #10 (permalink)
kalpik's Avatar
Where are you dude!!! The latest version is v3.1!
http://trillian.cc
kalpik is offline
Old 08-10-2005, 07:20 PM   #11 (permalink)
Just Do It
Charley's Avatar
Yes, i know that .... Didnt install it as it wud hog resources and i stuck to the older one.....
Charley is offline
Old 08-10-2005, 07:23 PM   #12 (permalink)
kalpik's Avatar
Actually yahoo, msn etc keep changing login procedures and servers every now and then. So i guess the version you have does not know the new login procedure of MSN! Thats why its not connecting. You can at least download the new version and see if it works, that way, we'l know whether the problem is the old version or something else!
kalpik is offline
Old 08-10-2005, 07:25 PM   #13 (permalink)
Just Do It
Charley's Avatar
Gimme the link so i'll try it now. How big is the file?
Charley is offline
Old 08-10-2005, 07:27 PM   #14 (permalink)
kalpik's Avatar
Its around 9 MB! http://www.download.com/Trillian/300...=dl&tag=button
kalpik is offline
- by bhaskar
- by soumya
