Hi
I want to install Framework .NET 1.1 SDK to use it with visual studio (Visual Basic .NET) 2002 IDE. As I searched the web pages, I find out it is not possible. Only VSNET 2003 works with framework 1.1.
Then, a freind of me who is also a student like me gave me a workaround.
Which is, first of all uninstall all framework 1.0. Now VSNET 2002 will not open giving a compiler not found. Now install framework 1.1 & SDK. Go to windows\Microsoft .NET\Framework and rename the folder 1.1*** to 1.0***.
In the VBNET2002 intallation folder rename the FramewokSDK to something and copy the .NET1.1 SDK 1.1 folder as FrameworkSDK in VBNET2002 installation directory.
Now everything works fine. I have prepared a small single form program (Hello World), which doesnot run on a win98SE with Framework 1.0 but runs ok in another one with Framework 1.1 redis*.
Is it possible to do things this way. Can I use these settings to build more complicated applications, like RDBMS later.
Thanks
