Old 01-10-2004, 06:59 PM   #1 (permalink)
Default Web programmer problem.....!
Dear,
Well i know HTML, and a bit of Java Script . Can work on Dreamveaver and Frontpage.... but i want to know more .... wht programming thing i shd learn after i know HTML... plz guide me ... will be thankful if u can give me the things to learn in a list.. cause when ever i try to learn something it say u must know other things first....
pratikbagaria is offline
Old 01-10-2004, 11:52 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm... learn CGI programming ... go for ASP or PHP. A bit of Flash will also help you.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 02-10-2004, 12:04 AM   #3 (permalink)
html is now nearly history, but its knowledge u will find it useful while learning the new things dhtml,cgi-perl,php-mysql, and dont forget xml
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 02-10-2004, 12:29 AM   #4 (permalink)
#/bin/sh's Avatar
1st learn java , jscript and asp
then u find no problem learning php .... etc
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 02-10-2004, 11:01 AM   #5 (permalink)
tuxfan's Avatar
Whatever it_waaznt_me said is just right. Go for PHP. I wouldn't recommend ASP. Learn MySQL with PHP. There is a specific book on the topic. That will help you make dynamic pages.
BTW, howsoever outdated HTML may be, you must know it.
tuxfan is offline
Old 02-10-2004, 11:14 AM   #6 (permalink)
FooBar Guy
GNUrag's Avatar
Aye techie bhai, what did you say again ? Can HTML ever be history ? Can C be history ?
http://web.gnuer.org
GNUrag is offline
Old 02-10-2004, 11:23 AM   #7 (permalink)
well thankz a lot... i know HTML is a kinda old ... but its useful .. and i know flash, photoshop, illustartor, coreldraw.....
Old 02-10-2004, 04:33 PM   #8 (permalink)
Default Re: Web programmer problem.....!
Originally Posted by pratikbagaria
Dear,
Dude,
You have just opened your eyes on Web programming, b4 u close, there are tons to learn from WWW !
* XHTML
* DHTML
* PHP
* PHP3
* ASP
* ASP.NET
* CGI
* PERL
* PYTHON
* WML
* XWML
and more stuffs to pop soon... get ready & go 4 it
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
go4inet is offline
Old 02-10-2004, 09:52 PM   #9 (permalink)
Version 2.0
Deep's Avatar
hmm i think if your logic is clear then learning the any web coding...
basially in simple language...
prog languages are simple english nothing else...
for example...
if you want to say..if user enters 5 then say hi else say bye
so in php u write like this..
<?php
if ($variable==5)
echo "hi";
else
echo "bye";
and in asp u write like this..
<%if numVariable = 5 then %>
Hi
<%else %>
Bye
<%end if %>
so the point is..logic remains same..what changes is syntax..and remember small pice of synatx should not be tough..
so i will suggest you to learn c, c++ and clear the logics then jump to php, asp whatever you want...(php will be my all time fav)
take help of http://www.w3schools.com/ or download couple of ebooks...(i had referred to learn php in 24 hrs..did some 2-3 chapers and then got bugged so started coding..and as and when errors used to come...google helped me..and php.net helped me too...)
for asp.net i will suggest...going for ASP.Net unleashed..its a great book..worth buying it..
and for c, there is a book by author Yashwant kanetkar - Let us C...great book...it had used that book to learn C...
i hope this info helps you to decide...
cheers
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 02-10-2004, 10:22 PM   #10 (permalink)
ya go for JavaScript, then go for ASP or PHP
suggest u go for PHP
or go for ASP & ASP.NET
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 08-12-2005, 10:10 AM   #11 (permalink)
Go for PHP & MYSQL, that will be enough. Enjoy!
rnaik is offline
Old 08-12-2005, 10:47 AM   #12 (permalink)
Version 2.0
Deep's Avatar
and what was the point in bumping so old topic?
Please take care from next time.
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
- by bhaskar
- by soumya
