Old 07-10-2005, 09:23 PM   #1 (permalink)
saptak
Posts: n/a
Default CD Drive trouble
I got meself a Samsung Cd riter which is currently in its second year.
I got a prob wid it. It can read cd's and if smthng is ritten on it, i can burn some more data on it.
But it isnt reading new cd's. It gives E:\Incorrect function or smthng error when i click on its icon.
Pleez tell me ---- is smthng rong wid cd riter or wat???
Old 07-10-2005, 09:32 PM   #2 (permalink)
q3_abhi's Avatar
Default Re: CD Drive trouble
Wat do u mean to say??
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 07-10-2005, 09:39 PM   #3 (permalink)
The Incredible's Avatar
does it works even once after u start ur pc or does it never works.
The Incredible is offline
Old 07-10-2005, 11:08 PM   #4 (permalink)
Netjunkie's Avatar
Isnt reading new cd's.!!!
You mean blank CDs without any data.
Man what's there in a blank cd for the drive to read.
Your CD drive is perfectly alright.
Netjunkie is offline
Old 08-10-2005, 12:17 AM   #5 (permalink)
saptak
Posts: n/a
Cmon Yaars
wat do u think..... i aint dat dumb
Wat i mean is (in simpler terms) dat wen i put in a blank cd in my cd drive...which is E:
an click on it, in My Computer, I dont go to E:\ but get an error sayin dat "Incorrect Function" Or value or smthng...i dont rem exactly!!
And yes, if i insert a cd which has smthng on it, i can read it perfectly well, even rite on it!!!! What is happening wid d new cd??? and i even got d cd tested on other PC... they're allrite
Old 08-10-2005, 01:04 AM   #6 (permalink)
siriusb's Avatar
If u have a third party recorder, then check if it is correctly installed. Also check if "enable cd rcording in this drive" is checked in the drive's recording tab.
siriusb is offline
Old 08-10-2005, 09:48 AM   #7 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Hey i had the same problem,it was not reading my CDs (written with DATA ofcourse.. ) so i got a PHILIPS CD LENS cleaner for Rs.140/-and cleaned the lens. The DRIVE worked for sum hours in normal state but i was again back to the same old condition where my CDs were not being read by the drive. So alas i hv to give it for repairing to the SAMSUNG wala's wich repaired my DRIVE for a whooping Rs.400/- (yeah i knw guys tat SAMSUNG drives do hv these problems with thme but i wouldrather get it repaired as i jus wanna use my old drive of 3 yrs old for sum more time b4 i switch on o a new SONY drive)..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now
- by bhaskar
- by soumya
