07-10-2005, 05:16 PM
how to join jpg with exe
hi
can any body tell me how to join jpg with exe to made a single exe file
07-10-2005, 05:19 PM
Senior Member
why would you wanna do that?
i smell something.....
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
07-10-2005, 06:18 PM
wht exactly do you want to do ?
do want an icon for your exe file ?
alibi
-Metallica
07-10-2005, 11:07 PM
9437077259
is that really possible! if yes, I too would like to know that...
08-10-2005, 12:10 AM
I don't know how exactly this works, but I heard that exe's have a jump instruction just after some sort of header which jumps execution to an offset where program code resides. Some viruses can inject themselves just after this jump and modify the jump offset to <previous offset>+<viral code size>. I am sorry if I am went wrong somewhere in my explaination, but a similar idea can be used here.
Just find that jump in a hex editor and edit it to the new value. Even if ther's no such jmp, you can insert one at the beginning. Again, I have only theoretcal knowledge and have not practised. Do try it though, it's fun.
08-10-2005, 11:58 AM
What he is asking is something different. Actually, there is a way to do join any files with another picture files and thus hide a file from prying eyes. I forgot what its called. But there are lots of softwares (some freewares as well) to do this.
08-10-2005, 12:11 PM
join server sun7 with jpg
i want to join
08-10-2005, 07:09 PM
Thats's called image steganography. hiding a file inside any other file is generally known as steganography. The most poular ones are image steganography and mp3 steganography.
Sometime you'll think you understand everything
...Then you'll regain consciousness
08-10-2005, 10:57 PM
The OP wants to incorporate jpg into exe and not vice versa.
Nice link to info on binders digen. Thanks.
08-10-2005, 11:38 PM
No problem.Glad it helped.
www.Oobertech.net
09-10-2005, 11:21 AM
you are right desertwind, that is what it is. Stegonography. But I was wrong. digen solved it
11-10-2005, 08:31 PM
9437077259
Can anyone pass on the link from where I can download a good binding software. I tried a few randomly from the net, but unfortunately they all turned out to be Virus. So please give good links where from I can really good binder to download.
Thank you.
Search this Thread |
