06-10-2005, 07:06 AM
Gracias Senor
Need Futuristic PC Config Suggestion..
hello all,
one of my relatives wants 2 buy a new PC which satisfies all the fields like Gaming, Media and Graphics.. a high end system is needed.. budget is 40K and not more than 45K.. So need sugg frm our members so it wil b easy for us to go and purchase as sugg.. i live in chennai.. Manually we hv decided upon a config on our own..
INTEL P4-LGA 2.66 GHz 800MHz, 1MB, Non-HT
INTEL MOTHERBOARD D915GLVGL 915G,V,S,NoPCX
HYNIX 512MB-DDR-400 400MHz - PC3200
SONY OEM DVD-Writer 16xD 16x, Dual Layer, 8.5GB
SS 160GB - SATA Baracuda / Puma 7200r
Zebronics Mid - 20 Models w/USB, Audio OR Fan
LG 17" LCD
Logitech SET - C.Less Blk Total Cordless w/Opti M
Altec Lansing Model# 251 5.1 HighQ - 90w RMS
APC UPS
Sugg if this config is ok or any changes to b made.. TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
06-10-2005, 07:45 AM
In Pursuit of "Happyness"
Why going for Intel? Go for AMD Athlon64. Thats the future! 64 Bit! Go for an MSI (nVidia nFORCE 4) board if going for AMD. For RAM, go for kingston or Corsair. Hard Disk: DO NOT BUY SEAGATE! It will crash within warranty itself (if you dont believe me, just do a search on hard disk on this forum and see for yourself!). Otherwise everything is OK.
06-10-2005, 10:59 AM
Manchester United
Ok, here is one of the possibilities:
CPU: AMD Athlon 64 3000+ (socket 939) ~ 7300
Motherboard: MSI RS 480M2-IL with integrated ATI graphics (since you have not mentioned that you will be into gaming or not). ~ 4900
Hard disc: 120GB/160GB (not Seagate, as mentioned earlier) ~ 3500
RAM: 512MB 400Mhz (256MB * 2, preferably Kingston or Corsair) ~ 2200
Optical drive:Sony/Liteon DVD-writer ~ 3500
Keyboard: Microsoft Internet keyboard ~ 450
Mouse: Microsoft/Logitech optical mouse (do not go for cordless if you specifically don't need it) ~ 350
Speakers: Altec Lansing 251/Altec Lansing VS 3151/Creative Inspire 5.1 5200 ~ 5000
Monitor: LG 17" LCD ~ 15000
Cabinet with minimum 300W PSU. ~ 1200
Total ~ 43400
This is relatively future proof, and you can make some changes. The LCD monitor is too expensive, you can always opt for a 17" flat CRT. Also DVD writer is not required unless you need to burn DVD's frequently. Go for a combo drive. In that way, you can save around 12000 bucks on both of these components and invest that money, in say a PCI-express graphics card like Geforce 6200/plain 6600, if the gaming bug bites you some time in the future, or maybe a better processor like 3200+. The 3200+ costs ~ 9500 and a 6200 graphics card ~ 4000. Or forget this if you are not a gamer, a better quality 5.1 speakers will be great, suppose a Logitech Z5300 (~12000).
Let us know your final decision on the config.
07-10-2005, 07:14 AM
Gracias Senor
thnx all.. but i hv mentioned tht the PC config shuld satisfy all the basic needs like Gaming, Media and excellent graphics.. due this only v r ready to spend a hefty amount.. so v need a PC since v r a "hardcore gamer".. and also in an idea of goin for a TV Tunercard to record movies and songs frm TV..
And also i hv not mentioned Seagate HDD.. i hv mentioned Samsung (SS).. cos i personally knw seagate is of no gud.. Also v r sure to go for a DVD Writer n LCD Monitor.. and also cordless Mouse n Keyboard..
So no compromises and later changes to b made.. a fully packed hardcore machine config is needed.. hope u guys can understand me.. and also <45K..
TIA
07-10-2005, 08:02 AM
D00d u mentioned barracuda as the hard disk! That IS seagate!
07-10-2005, 09:19 AM
Are u sure 45000 is a hefty amount ??  ur futuristic PC is will cost u a lot more...
If u are decided with the LCD+ DVD writer that takes out around 12k (conservative estimate) out of ur budget!
u are left with 30k out of which u ll only get a budget/entry level system.
Here are some suggestions fr u, since u are only going to use ur pc as a gamin machine:
i) get athlon 64 2800 + s754 mobo to cut down costs...
ii) get a gfx card ! 5000 bucks of more gfx power will help u more in games than twice the amount u spend for ur other components
I m too lazy to write a full configuration, but you can also look at the configuration suggested by digitized.
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
07-10-2005, 11:34 AM
AMD Athlon64 3000+ 7200
MSI RS480 M2- IL 4900
2*512MB DDR400 Transcend 4900
120 GB SATA 3300
LiteOn DVD DL 3100
Samsung 17" 5400
Creative Inspire 5.1 4800
XFX / BIG 6600 Non-GT 6800
Keyboard and Mouse 1200
Cabinet + SMPS 2500
Total 44100
Education... has produced a vast population able to read but unable to distinguish what is worth reading
08-10-2005, 07:17 AM
Gracias Senor
Total ~ 43400
Wil go with u Digitized... But u hv mentioned..
But v r into hardcore gaming.. so shuld i go for a change or stay with the same motherboard.. cos u hv mentioned if iam not into gaming i can go for MSI RS 480.. Juz clarify this..
08-10-2005, 08:00 AM
He said that cuz the motherboard has an on-board graphics card. Go for a separate graphics card.
08-10-2005, 09:14 AM
Manchester United
Total ~ 43400
The MSI motherboard has on-board graphics and also a separate PCI-express slot. You can buy a 6200/plain 6600/6600GT (this is for hardcore gaming) if you save some money on the monitor and buy a CRT one.
Thanks that you liked my config.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
08-10-2005, 09:41 AM
Gracias Senor
So if needed i can go for the Xtra Graphics Card either 6200/6600/6600GT.. i think iam rite.. any ways thnx for all help.. if any more pls keep it flowin..
TIA
08-10-2005, 12:49 PM
Manchester United
Ya, and get a Leadtek graphics card, they rock!!! You are very much correct, and you have to disable the on-board graphics from the BIOS if you install a separate 6200/6600/6600GT.
Search this Thread |
