Old 06-10-2005, 12:12 AM   #1 (permalink)
Default 2d pointers, memset or how to initialise?
hi,
suppose i have
main()
int n=6;(which means i am to generate a 6*6 matrix)
int **a;
and some how i allocated the memory required for 6*6 to the pointer a....
now, how do i initialise the elements of pointer a to "0" so that i can start accessing them as arrays without any junk values... coz, in my program some values r untouched and if i initialise to "0", it wud be fine, with junk its jus disappointing... i hav heard of memset command for 1d pointers, is it possible ot initialise 2d pointers using the same? thk u.
/legolas
legolas is offline
Old 06-10-2005, 01:05 AM   #2 (permalink)
gtoX's Avatar
Well, it depends on the reqd. speed of program you are creating.
You could create an initialisation portion inside the main() fnx., inside a for loop.
If it is time-critical, I suggest you use assembly codes in place of the for loop if your compiler supports it.
i think memset also works, because all it requires is the starting address(in your case, the int 'a'), and the total size of the array(6*6 = 36), irrespective of the dimension of the array. However, I haven't personally done that. You could try it out.
The trouble with wanting something is the fear of losing it .....or never getting it. [ Max Payne(2) ]
What is mind? No Matter..... What is matter? Never Mind [Homer Simpson]
gtoX is offline
Old 06-10-2005, 12:24 PM   #3 (permalink)
aadipa's Avatar
In reality, you will not need pointers to pointers (2D pointers) to store a matrix, a simple pointer will do, all you need is a mapping function.
Say I want to store a[6][6] in *p, then a[i][j] is *(p+(i*columes)+j)
A real use of pointer to pointer is when you need to exchange the rows in the matrix, or when you have to store array of different lengths and need a same mapping function.
In that case
int **p;
p = (**int) malloc(sizeof(int *)*ROWS);
for(i=0; i<ROWS; i++)
    *(p+i) = (*int) calloc(sizeof(int), COLS); // calloc will set all to 0
*(*(p+2)+4) = 5;  // Same as  a[2][4] = 5
Here the mapping function becomes a[i][j] = *(*(p+i)+j)
I have not checked the code as I don't have any C compiler on my desk right now, but I think it is correct. Just try and reply. i hope that was what you wanted.
aadipa is offline
Old 06-10-2005, 11:36 PM   #4 (permalink)
@aadipa,
thks for the initialisation help, but i needed 2d pointers coz, i am using arrays of size 1000*1000 or more even and so i cant declare them static... the stack memory gts exceeded, so i got 2 make sure that i free them asa their need is over.. and moreover, with pointers, the stack memory usage is also better... i tried a different initialisation thou, it worked, and i am sure the initialisation i gave wud work either, coz i understood a lots abt these owing to that implementation.. thks for ur help.
/legolas
legolas is offline
- by bhaskar
- by soumya
