05-10-2005, 11:55 PM
120 mm tricolour fan
hi people , I am looking for a 120 mm tricolour fan for my casing . only being able to find antec one for 1.7 k ... which is way too much ..
anyone has any other suggestions?
pls help
06-10-2005, 02:15 PM
seems interesting...i m also looking for similar product...
06-10-2005, 03:04 PM
antec is the only one providing those fans in india
sorry
No Mercy, No Limits.
06-10-2005, 06:25 PM
see I have got two 80 mm four colour fans from my friend in dubai , which are 110 rs each .
I am waiting for a 120 mm colour one .. which will take time .. that's why I was looking for it in our local market . but seems like there is no other option to antec which is way tooooooo costly..  guess like I will have to wait..
06-10-2005, 06:54 PM
Yep Antec is doing a killing cause it is not available in India, I was looking at the web and they had 400W power supply with 2 fans, led and all the gizmos for $30. Yet I had to pay $15 for a el cheapo 350W power supply that barely runs cause the antec one costs rs2000. All these cases, fans, led's etc are dirt cheap sicne they are chinese made and costs only a few bucks. But when you cant find them, they can charge you premium.
06-10-2005, 09:17 PM
ebay ppl are selling it.. maybe contact seller directly and u can get it cheap.. all antec SMPS and fans.. and paste too..
ANTEC COOLING - 120 MM Tricool Fan is hardly 930 bucks there from Antec
I\'M BACK
07-10-2005, 12:37 AM
hey khandu , that is a tricool fan not tricolour fan ...
get ur facts right
07-10-2005, 08:05 AM
my fault
I\'M BACK
07-10-2005, 09:42 AM
The Hardware Labs
@yogi
I could not find any tricolour 120 mm fans but found a coolermaster UV 120MM FAN with 5 colour options .. it costs only 400 bucks and is available from SMC International (check the master h/w contacts list sticky for their contact details) .. currently only the blue n purple colours are available though.. for the specs n pics go HERE
07-10-2005, 10:27 AM
hey thank you all guys ... mohit specially ... people my heart says to get the antec one .. but my mind says its too expensie .... I am confused ...
Lets see what happens ?
07-10-2005, 10:47 AM
Macboy
even though I didn't ask the questions,I must thank you all for I am happy I finally found some antec fans and UV lights at reasonable prices...
Thanks a lot.
I'm like a bird... :)
08-10-2005, 10:20 PM
hi guys i have found a other way around ... there is one more option to have 120 mm colour fan cheaply .. now we have to get a 120 mm fan whose blades are of white colour and then we can fit colour leds in it .. its easy..
but can anyone tell me where can i get a fan like that?
08-10-2005, 11:44 PM
Macboy
One more question, where to find those damned LEDs? Can anyone please send me those? I will pay for them and whatever trouble one goes through...
08-10-2005, 11:55 PM
i know where we can find these leds .. but the main prob is to find white 120 mm fan ... in market only black one are available ..
someone pls help ..
09-10-2005, 01:51 AM
transparent fin fans are not or very rarely available
i havent seen one yet
sorry boys
09-10-2005, 07:22 AM
Guys the Coolermaster UV Fans are transparent
just check them.
Get it for Rs 400.
Check this link properly
Link: http://www.coolermaster.com/index.ph...20%20x120%20mm
And LED's are available at any electronics shop.
Antec is simply overpriced
Overclock Me.
Overvolt Me.
AMD Me.
09-10-2005, 10:04 AM
Macboy
The thing is, I will be buying the UV light, UV ATA cable, and a UV Fan. I wanted to install some LEDs around the place for added....pleasure. I have checked at the electronics shops out here but they have no Idea so I was wondering if someone could help.
09-10-2005, 10:21 AM
ok guys , if i get a silent 120 mm uv fan -blue -- and it costs 520 rs in mumbai ... i will solder some leds on it ... then will it work? got to ask the friend who is will be doing this work for me ..
will this work ? or i have to get a uv light ? but then the total cost will be same as the original trilight fan ?
pls help ..
09-10-2005, 12:58 PM
#19 (permalink)
if u have a freakin uv fan its better u get uv light for it dude !
whats the point in destroying the fan tryin to mount LED's on it ?
09-10-2005, 01:36 PM
#20 (permalink)
hey raven , it's the total cost buddy , uv fan costs 520 of coolermaster and antec internal uv light costs 1120 and antec trilight costs 1716 rs. so anyways the total cost is way too much .. got my point ..
09-10-2005, 07:17 PM
#21 (permalink)
yeah i do get your point
but the the fact remains if u buy a uv fan and then mount the LED's on it then might as well just get a normal fan and mount LED's on it instead of wasting a 520 uv fan when u cant even light it up with UV light !!
i hope u get what im tryin to say
09-10-2005, 07:24 PM
#22 (permalink)
but are there any fans with white colour blades available in market . all fans available are black in colour .. if there are any white colour fans then do let me know where i can find those in mumbai? see i was not getting any of these fans that's why decided to go for the uv fan which i must state is the cheapest option available ( even it costs 520 bucks ) ...
so pls guide ... :roll:
09-10-2005, 11:14 PM
#23 (permalink)
Macboy
I think on ebay.in there was a white (transparent) fan for less than 500 bucks...
10-10-2005, 01:56 PM
#24 (permalink)
Macboy
One more question.
I got the LEDs (Red and white) but don't know how to fit them inside. Can I fit them using those power connectors for the HDD? If yes, which cables should I use for the purpose?
10-10-2005, 03:06 PM
#25 (permalink)
ok dude  go with the uv fans if u want
@goobi yeah those will do .. but then the LED's will flicker with the the HDD LED
u can use the power LED wires .
just use normal wires like the one u see for the power LED n all
also u wont be able to connect 3-4 LED's to that line since they wont take the load since the current is divided
u have to see the specification of each LED and attatch them accordingly
mostly ull have to design a circuit to accept incomin voltage from a molex connector and to drive those LED's
10-10-2005, 03:14 PM
#26 (permalink)
ok i am done with this led stuff . i am getting antec tricool trilight 120 mm fan from outside for 900 rs .. that's it .......
10-10-2005, 03:20 PM
#27 (permalink)
The Hardware Labs
from where ????
10-10-2005, 10:29 PM
#28 (permalink)
from a friend in dubai
Search this Thread |
