Old 05-10-2005, 01:40 PM   #1 (permalink)
Traceur
zegulas's Avatar
Default .rar%20
I downloaded some splited video files, they had this extension .rar%20
I am not able to open it even using winrar, wat shld i do???
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 05-10-2005, 02:18 PM   #2 (permalink)
Karthiksn
kato's Avatar
this is just a wague idea but try and change extention to rar that means simply remove %20
"Walking the Path of Heaven, The Ruler of All."
kato is offline
Old 05-10-2005, 03:09 PM   #3 (permalink)
alib_i's Avatar
when rar splits files .. then it names it as
.rar
.r01
.r02 ....
you keep all files in one folder and open .rar file and it reads all other files and extracts.
so i think there is something wrong in the names ..
one of the files is .rar file and others must be named as .r01,.r02,.r03,... and so on.
alibi
-Metallica
alib_i is offline
Old 05-10-2005, 03:47 PM   #4 (permalink)
Another Brick in the Wall
drgrudge's Avatar
I guess you got a lot of this small .rar files which together constitutes a other file like a movie etc.. just open any one of the .rar file and extract it to the folder same as that of the .rar files..winrar will do the job and extract the whole lot of that thing and you shall have the desired file with you.
Follow these steps and you are done:
You need to download WinRAR - http://www.rarlabs.com
Then, I assume your some rars like; .rar .r01 .r02 .r03 etc
Just open the .RAR file and extract the contents, it will automatically extract from the other rars assuming they're all in the same directory.
If you put all the 50 files in one folder, the .rar and the .r01... etc
Then install WinRAR, the icons of the .rar..r01 will change now.
Then just double click on the .RAR file and you will see the movie file in WinRAR - you then just extract this, you don't need to open the .r01.. etc as WinRAR extracts from those automatically.
drgrudge is offline
Old 05-10-2005, 07:06 PM   #5 (permalink)
alib_i's Avatar
i think he has winrar already
alibi
-Metallica
alib_i is offline
Old 05-10-2005, 10:36 PM   #6 (permalink)
Traceur
zegulas's Avatar
Lemme tell u something new, when i double click on any of the rar files (removing %20), winrar gives the following error: the rar files is either damaged or corrupt!!!
zegulas is offline
Old 05-10-2005, 10:50 PM   #7 (permalink)
There is a possibility that you are downloading the actual video file itself and not rar files. Check the website that you downloaded it from for any information about this... If not, try changing the extension to one of the video formats (avi, mpg, mpeg, wmv, rm, mov, etc) and opening them in media player...
If you are sure that it is an archive, try repairing the file in WinRAR...
If all else fails, report the problem to the website and see if they can help you out...
Arun
sakumar79 is offline
Old 06-10-2005, 12:21 AM   #8 (permalink)
alib_i's Avatar
that is because the order of files is screwed up
ie., in a set of .rar, .r01, .02, .. etc files ..
if you switch the names of .r04 to .r05 and .r05 to .r04,
you will get the 'rar is corrupt' message ..
all files need to be correctly named .. not just the one .rar file
every file should be named correctly.
you either need to get the info of which file is what .. or redownload the whole thing
alibi
-Metallica
alib_i is offline
Old 06-10-2005, 10:02 AM   #9 (permalink)
rename the file to .avi or .mpg and try to open it
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
- by bhaskar
- by soumya
