Hey all,
I have a computer with the following config:
AMD Athlon64 2800+
512MB DDR333 RAM
K8N Motherboard
GeForce4MX
Samsung 80G HDD (SATA)
Seagate 20G HDD (7K RPM)
Microsoft Keyboard&Mouse
Samsung 17"
Windows XP SP2
APC UPS (Software loaded on comp)
Airtel ADSL conn
Well, the problem is that recently whenever ive started shutting down/hibernating, the computer goes uptil "
Saving your settings" and then just freezes! Ive tried taking advice from some sad@$$ forums online but they dont have a clue. This month i restarted buying DIGIT and i know how tech-savvy its subscribers are... Well, I really hope someone can suggest a remedy..Btw, even the APC UPS s/w initializes the hibernation process but doesnt get beyond the "
saving your settings"!
Also, recently when i disconnect from the net (
right-click in sys tray conns icon), it the connections just freezes and i cannot reconnect either!
Regs,
Rahul
