Originally Posted by Mangal Pandey
plz suggest how to merge 5 .iso cds of fedora core 3 (i have got with the book "Fedora Core 3") into a single DVD.
An easy method will be ordering a DVD installation disk from Linux distributers. This will serve cheap.............
But if you want to burn them, just extract the boot image of the first CD with the help of tools such as ISO buster............... then burn all other ISOs as data and the boot image as a boot image on a DVD........... Then during installation choose to install from ISO and give the location........ For some help, you may want to know how to install it from HDD so that you can foloow the same process for installation from DVD........
How to install Fedora Core 4 (3 is also similar) from HDD
