Old 04-10-2005, 10:47 AM   #1 (permalink)
Yoda's Avatar
Default How to Mount a CD or DVD image using A120% or Deamon Tools.
Hello Friend,
I've heard many using Deamon Tools and Alcohol 120% to mount CD and DVD images. I tried Deamon Tools but I don't know how to use them or emulate or mount the Image files. It was very confusing for me.
Please can someone guide me or give a Tutorial on how to use Deamon Tools and Alcohol 120%.
and... can I install both Deamon and Alcohol in my PC. Will there be any conflicts between the 2 softwares. Is there any instructions or rules to be followed while installing these 2 softwares.
I've a Clone DVD Image. It has 2 files. "XXXXX.mdf" and "XXXXX.mds".
If I've mount the Image then which file extension should I select.
Like wise what about other image files like ISO, "Bin and Cue" and .nrg
And I've Burn a Clone DVD Image then which software will be good for it.
Alco 120% or Clone DVD and which file to Burn "XXX.mdf" or "XXX.mds"
Thanx in Advance.
Arsenal.
Yoda is offline
Old 04-10-2005, 11:05 AM   #2 (permalink)
jUST INSTALL ALCOHOL 120% AND ADD THIS FILES TO THE ALCOHOL LIST USING THE INBUILT ALCOHOL IMAGEFINDER
FOR MOUNTIG THIS DRIVES U CAN DOUBLECLICK ON THEM
AFTER THEY ARE MOUNTED ONCE THE LIST IS AVAILABLE ON RIGHT CLICK ON THE VIRTUAL DRIVE
Education... has produced a vast population able to read but unable to distinguish what is worth reading
AGENT_SMITH is offline
Old 04-10-2005, 02:38 PM   #3 (permalink)
Daemon Tools online help -
http://www.daemon-tools.cc/dtcc/portal/daemonhelp.php
Mounting an image:
1. Right-click on the DAEMON Tools trayicon
2. Select Virtual CD/DVD-ROM
3. Select Device [?:]
4. Click Mount
5. Browse and select the image you wish to mount
6. Click OK
Keith
Keith Sebastian is offline
- by bhaskar
- by soumya
