Old 04-10-2005, 09:33 AM   #1 (permalink)
Default power off button not working for shutting down
i have just installed win 200 pro and i have strange problem
i systematically shut the computer down......
and it gives the
"...computer is safe to be turn off"...
but after that power off button dont work...
i dont think it is mechanical error as it work to turn on the computer...
and i have tried resgistry edit as well but doesnot work
whats the problem.............?
be who u r :
Saharika is offline
Old 04-10-2005, 04:49 PM   #2 (permalink)
pradipudhaya's Avatar
Its already switched off.. No need to press the power off button..
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination - if you don't, I'll set Bunny onto you!
pradipudhaya is offline
Old 04-10-2005, 10:26 PM   #3 (permalink)
hi,
is your cabinet ATX. ie..did it use to switch off automatically before installing win2000 Pro?
for now press and hold the power for 3 to 5 Secs. the system will get switched off.
thank you.
For The World You Are Someone...
For Someone You Are The World...
prathap_lab is offline
Old 05-10-2005, 09:09 AM   #4 (permalink)
my mother baord is indeed ATX
by the way i think its not windows 2000 problem but hardware it self
about first answer i think my computer is not off as every thing fan ,cpu seems running...(is running) though it says "safe to turn off'
i will try second option...
by the way is it mis intsalling or joing cable pins where one should not have joined...
a amatuer hardwaien just assembled the computer reading guides from the sites...
but other things are ok,.....
is it hardware problem...?
be who u r :
Saharika is offline
Old 07-10-2005, 07:33 PM   #5 (permalink)
Originally Posted by prathap_lab
hi,
thank you.
ya pressing key for 5 sec it turned off
whats the problem
how can i fix it
thanks
saha
be who u r :
Saharika is offline
Old 07-10-2005, 08:20 PM   #6 (permalink)
Karthiksn
kato's Avatar
hey i dont think thats a problem as it had been the case for my computer but as i never use my computer in safe mode it shuts down directly switching off the CPU
"Walking the Path of Heaven, The Ruler of All."
kato is offline
- by bhaskar
- by soumya
