Hai Friends,
i have Problem In my Booting Itself,when i switch on My PC some times it will show
Disk Boot Failure Insert Disk. Like This.....
Again i switch Off My system And adjust the the Power Cable & Data Cable then i will Switch on the system. It will start Normally.Some Friends Told May be Your Harddisk Problem,Another some friends told may be your SMPS wire can be problem get Some Conector and Try to solve that,another set of persons told Replace Your SMPS.
I am so confuse in that......so,guys tell me the Good Remedy to solve This one
Ok Take Care Bye
